William,
I don't know why Jeshua wrote to you since I maintain the wikidot site. I think that GSL is there simply because I went to your frameworks site and pulled in all frameworks you had on the main page. But you're right. I don't use it in my configure AFAICT. I suppose I should remove it it if doesn't do anything.
As for the other issues, I'll respond
1. There IS a link to the Kyngchaos frameworks page in the menu on the right side that shows up on every page. On that frameworks page, it is clearly stated that PROJ and UnixImageIO are a part of the GDAL Complete package
2. AFAIK, the order of installing the main frameworks packages makes no difference. The ones for which order matters are included in GDAL Complete. If I am wrong here, please let me know and I will put a note on the site.
3. No one has ever reported this permissions issue so far. I don't know what is causing it in this case (unless it is new for 7.0 stable). AFAIK, the only permissions issue is the need to have a writeable director called "bin" inside the GRASS folder if you are installing extensions. This is a weird quirk of the extensions build system on the Mac. If there is a new permissions issue for 7.0 stable, it needs to be reported. But I have built it in exactly the same way as I've built all other builds recently.
Michael
____________________
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Feb 22, 2015, at 5:17 PM, William Kyngesburye <woklist@kyngchaos.com> wrote:
PROJ and UnixImageIO are a part of the GDAL Complete package. Once that is installed (it is the first listed, though order is not specified), the others can be any order.
I don't know why GSL is there, that's something I did for QGIS. Michael?
On Feb 22, 2015, at 4:25 PM, Jeshua Lacock <jeshua@3dTopo.com> wrote:
Greetings,
I noticed the following minor issues while installing GRASS 7.0.0 on Mac OS X. While they are not any obstacles for me, it may block some others from a smooth installation. Therefore I would recommend adding a the following notes to the install page (http://grassmac.wikidot.com/frameworks).
1. The install page does not link to the PROJ or UnixImageIO Frameworks:
http://www.kyngchaos.com/files/software/frameworks/PROJ_Framework-4.8.0-1.dmg
http://www.kyngchaos.com/files/software/frameworks/UnixImageIO_Framework-1.5.0.dmg
2. The order of the install packages for some of the packages is important. It may be nice to list the order in which to install the frameworks (perhaps order the list?)
3. Following successful installation of the GRASS-7.0.pkg the installed directory permissions are set that a user cannot open the folder until changing the permissions from:
drwx------ 3 503 wheel 102 Feb 22 14:09 GRASS
This can be resolved by adding “sudo chmod -R 755 /Applications/GRASS” (or similar) the the package installer postflight script.
Thank you so much for all the development over the decades GRASS GIS Team!
Jeshua Lacock
Founder/Engineer
3DTOPO Incorporated
<http://3DTOPO.com>
Phone: 208.462.4171
grass-user mailing list
grass-user@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
