[GRASS-user] A color rules - a little issue
Hi
I have a suggestion about color managment in grass
I just work on couple of maps where I need to prepare custom color schemes (rules). Using the r.colors.rules is slighty (Hmm... rather strongly) uncomfortable.
To omit it I replaced dir colors in ../grass63.cvs/etc/ dir with simlink to dir in my home directory and I create new rule file every time I must experiment with colors.
It is not good solution for two reason:
1) every new grass complilation makes problem with symlink
2) I have over 60 rules files in one directory and the number increase
Is possible to create solution similar to r.reclass.file to use custom color rule file from anywhere in file system?
regards
Jarek
Jarose-Bław Jasiewicz wrote:e-A
Have you tried:
  r.colors map=... color=rules < rulesfile
If you want to use the above from gis.m, save the attached script as
$GISBASE/etc/gm/script/r.colors.file, and add the following line to
$GISBASE/etc/gm/gmmenu.tcl near the one for r.colors.rules:
    {command {[G_msg "Set colors using rules file"]} {} "r.colors.file" {} -command {execute $env(GISBASE)/etc/gm/script/r.colors.file }}
Or you can make the changes in the source tree (replace
$GISBASE/etc/gm with gui/tcltk/gis.m in the above paths) if you want
them to survive "make install".
(attachments)
r.colors.file (1.1 KB)
Thanks, that is exactly what I need...
I hope it will be included in newest cvs...
Thanks
Jarek
19/3/2007, "Glynn Clements" <glynn@gclements.plus.com> napisa³/a:
Jarose-B³aw Jasiewicz wrote:e-A
Have you tried:
Yessssss...., so I haven't try :frowning:
merged into gui/tcltk/gis.m/script/r.colors.rules in 6.3 CVS.
Hamish
