[GRASS-user] A vector layer
What does it mean when it sais
Fallo de segmentación (core dumped)
once I run the v.digit command it makes a new map and then it shows this mistake please if some one could help me!..
i also tried to use r.to.vect but i got this message
r.to.vect
WARNING: coor files of vector ‘rasttovect@destimap’ is larger than it
should be (14 bytes excess).
WARNING: Cannot display areas, topology not available
thank you for your help
Hola Isabel and all,
Isabel Alfaro Cardozo ha escrito:
It means that an error occurred while v.digit was running. Usually, after that error the vector map is not created correctly. That's why you get those other warnings below.
Maybe, someone in the list could help and you if you explain what you tried with v.digit.
r.to.vect
WARNING: coor files of vector 'rasttovect@destimap' is larger than it
Un saludo,
Roberto.
ah... ok...
use:
v.build map=mapname
then retry with v.digit over the same map....
Il giorno gio, 01/11/2007 alle 23.24 +0100, roberto.antolin@polimi.it ha
scritto:
tried with v.digit.
> r.to.vect
Un saludo,
Roberto.
grassuser mailing list
grassuser@grass.itc.it
Ti prego di cercare di non inviarmi files .doc, .xls, .ppt, .dwg.
Preferisco formati liberi.
Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: marchesini@unipg.it
        ivan.marchesini@gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73@jabber.org
