Hi GRASS GIS mailing list
Regarding r.geomorphon,
in the ternary pattern of the analysis result,
there is a description in the manual that you want to see pattern.txt in the source code directory to see all the patterns.
However, there is no file named pattern.txt in the code directory.
If you know the location of the file,
could you please tell me?
Thank you.
Ueda
Hello Ueda,
Indeed there’s no pattern.txt in the source code of r.geomorphon, and it was also not there when the module was moved from addons to core. The only pattern file is a c file. Maybe a typo in the manual page? Did you have a look at the pattern.c file?
Vero
El dom, 26 jun 2022 a las 15:05, Mitsunori Ueda (<inkyo.3215@gmail.com>) escribió:
Thank you.
Ueda
grass-user mailing list
grass-user@lists.osgeo.org
Hello Veronica
Thank you for replying to my email.
I have not checked the file yet.
I will check it.
Thank you.
Ueda
2022年6月27日(月) 18:04 Veronica Andreo <veroandreo@gmail.com>:
Hello Ueda,
Vero
Thank you.
Ueda
