Hey all
While I was reading G_window_rows definition at GRASS6 programmers manual, I found this definition:
Number of rows in active window.
What does active window means? Because I can read number of rows/columns from raster header. I’m not real sure of what is active window.
Thanks
Franz
from raster header. I'm not real sure of what is active window.
The "window" specifies the relationship between row/column indices and
cartographic or geographic coordinates.
All raster processing is performed on the grid specified by the
window; all input maps are automatically resampled to it.
Unless the program explicitly sets a window, it will be initialised
based upon either:
1. The contents of the GRASS_REGION environment variable.
2. The contents of the named region specified by the WIND_OVERRIDE
3. The contents of the WIND file in the current mapset.
The most common case is #3.
Programs which explicitly set a window include r.resamp.interp,
r.resamp.stats and r.resamp.rst. These all set the window to match the
input map, so that they read the "raw" data without any resampling.
