[GRASS-user] Adding v.vi from the repository
Hello,
A quick question about compiling GRASS add-ons which I have been having some trouble with despite hours pouring over the instructions!
I am running 6.4 on Ubuntu Hardy and the package I need is i.vi for vegetation indices https://svn.osgeo.org/grass/grass/trunk/imagery/i.vi/. (I notice that there is also a version of this under the gipe repository here: https://svn.osgeo.org/grass/grass-addons/gipe/ but am not sure if this is the same as it mentions no speed ups (?) on the wiki page http://grass.osgeo.org/wiki/GRASS_AddOns#GIPE)
I have read the instructions at http://grass.osgeo.org/wiki/Compile_and_Install#Addons but being a bit of a noob I don’t really understand what I need to do to compile the add-on.
I have tried saving all the files in the i.vi directory to my usr/src/grass source directory then following the Wiki instructions compiling the file from there, but this just gave me an error message (I have included the terminal output below this message so you can see what I did).
I’m probably just missing something obvious but I’m afraid don’t have enough understanding to make it work - any help would be much appreciated!
Thanks
Rebecca
rebecca@horizon:~/src/grass$ ls
arvi.c evi.c gemi.c ipvi.c main.c msavi2.c ndvi.c savi.c vari.c
dvi.c gari.c gvi.c i.vi.html Makefile msavi.c pvi.c sr.c wdvi.c
rebecca@horizon:~/src/grass$ make MODULE_TOPDIR=/path/to/grass64/
Makefile:8: /path/to/grass64//include/Make/Module.make: No such file or directory
make: *** No rule to make target /path/to/grass64//include/Make/Module.make'. Stop. rebecca@horizon:~/src/grass$ make MODULE_TOPDIR=/path/to/grass64/ Makefile:8: /path/to/grass64//include/Make/Module.make: No such file or directory make: *** No rule to make target /path/to/grass64//include/Make/Module.make’. Stop.
rebecca@horizon:~/src/grass$ make Makefile=/usr/bin/grass64/
Makefile:8: …/…/include/Make/Module.make: No such file or directory
make: *** No rule to make target ../../include/Make/Module.make'. Stop. rebecca@horizon:~/src/grass$ sudo make Makefile=/usr/bin/grass64/ [sudo] password for rebecca: Makefile:8: ../../include/Make/Module.make: No such file or directory make: *** No rule to make target …/…/include/Make/Module.make’. Stop.
rebecca@horizon:~/src/grass$ alias gmake64=‘make Makefile=/usr/bin/grass64/’
rebecca@horizon:~/src/grass$ make Makefile=/usr/bin/grass64/ install
make: *** No rule to make target `…/…/include/Make/Module.make’. Stop.
Rebecca,
   What is the fully qualified path to grass64? For example, here it's
/usr4/grass64. What you want to define for MODULE_TOPDIR is the actually
path to your grass64 source code. What you've specified above is a generic
place holder.
Rich
