[GRASS-user] announcement of strahler stream order analysis
Hi list!
I just finish first version of new grass module r.stream. Module is regular Grass module, written in C an has no addational dependencies. It was compiled with GRASS65 devel downloaded in last two week. Source code you can find here:
http://heretic.livenet.pl/heretic/r.stream.tar.gz
Module compiles and seems to work. Analysis was tested only on one dataset.
To compile it copy r.streams directory to your grassXX../raster/ cd r.stream run make and make install
What module calculate:
- strahler stream order
- shreeve stream magnitude
- class of topological elements of drainage networks
Module use r.watershed outputs: SDF flow direction and SDF stream network.
Analysis of r.stream shall be run on same regions setings as r.watershed. If no, run g.region rast=your_dir_file first. For now module do not check if region and rasters are identical. It is planned to add in nearest feature. It also do not check if dirs and streams are SDF result. Threre are no addational description. It will be added after testing.
It works only on cells data. Floating points data are not allowed (and have no sense).
Module is quite fast. 3000 x3000 cells all three analysis runs no more than 30 s. on AMD 3800 2GB, Ubuntu 8.04
Module is part of comprehensive project which will add full Horton analysis and some addational terrrains analysis to Grass. More details in the feature. Any cooperation is welcome. The next module I plan is directional vectorisation of stream network.
For now module is available only form web address pointed below. After testing and removing critical errors it will be added to grass add-ons (or maybe to main branch?).
Any coments, improvements and critics is very welcome.
More advanced Grass developers: Please check my code. Its funny, but I don't know C.
General code is based on GRASS r.topindex module (by Keith Beven and Huidae Cho, strongly modified)
Strahler stream order algorithm from Saga GIS (by Victor Olaya, modified)
Shreeve stream magnitude and class of topological network are my own ideas
Test and enjoy.
Jarek Jasiewicz
Adam Mickiewicz University, Poznan
Geoecology and Geoinformation Institute
This is a module I've been looking for a long time.
compilation went OK, but when I run it:
GRASS 6.5.svn (itarare_250k):~ > r.stream
too many nested evaluations (infinite loop?)
    (procedure "Gronsole::add_data_tag" line 4)
    invoked from within
"Gronsole::add_data_tag $path $ci out"
    (procedure "Gronsole::readout" line 15)
    invoked from within
"Gronsole::readout $path $ci $mark $fh"
    invoked from within
"if [eof $fh] {
                Gronsole::readeof $path $ci $mark $fh
                Gronsole::done_command $path $ci
        } else {
    (procedure "Gronsole::file_callback" line 2)
    invoked from within
"Gronsole::file_callback .nb.fOutput.gronsole 1 cmdinsert1 file6"
and then it hangs...
cheers
Carlos
2009/7/26 Jarek Jasiewicz <jarekj@amu.edu.pl>:
Hi list!
can find here:
no sense).
know C.
Test and enjoy.
Jarek Jasiewicz
grass-user mailing list
grass-user@lists.osgeo.org
Carlos Henrique Grohmann - Geologist D.Sc.
a.k.a. Guano - Linux User #89721
ResearcherID: A-9030-2008
http://digitalelevation.blogspot.com
http://www.igc.usp.br/pessoais/guano
_________________
Can’t stop the signal.
Carlos Grohmann pisze:
    invoked from within
    invoked from within
    invoked from within
"if [eof $fh] {
        } else {
    invoked from within
cheers
Carlos
Yes I noticed it, run it form command line with full paramteres without GUI for unknow reason. I also cannot run via GUI. I hope someone more advanced will help me remove that error. I dont know why it happens.
Give me feedback if you will run it with success.
Jarek
Hi list!
can find here:
no sense).
know C.
Test and enjoy.
Jarek Jasiewicz
I will upload little newer version without debbuger messages which may cause that messages
Now I absolutely sure it is from tcltk, but on my machine it work now fine. I tested it also on spearfish dataset, no problem for now.
Jarek
Yes! Runs fine from command line! SO much better than using JGRASS.
cheers
Carlos
   invoked from within
   invoked from within
   invoked from within
"if [eof $fh] {
       } else {
   invoked from within
cheers
Carlos
Jarek
Hi list!
regular
you
can find here:
dataset.
network.
If
feature.
have
no sense).
than
analysis
directional
(or
don't
know C.
Huidae
ideas
Test and enjoy.
Jarek Jasiewicz
Hi Jarek
Can use this on a LatLong mapset where my unit is not meters?
Thanks for the effort!
milton
Hi list!
To compile it copy r.streams directory to your grassXX…/raster/ cd r.stream run make and make install
  • strahler stream order
  • shreeve stream magnitude
  • class of topological elements of drainage networks
More advanced Grass developers: Please check my code. Its funny, but I don’t know C.
Test and enjoy.
Jarek Jasiewicz
try, I don't know I haven't LL location to test it
but it shoud work
program do not use any inforamtuon about units and units conversion
Jarek
Milton Cezar Ribeiro pisze:
Hi Jarek
milton
2009/7/26 Jarek Jasiewicz <jarekj@amu.edu.pl <mailto:jarekj@amu.edu.pl>>
    Hi list!
    dataset.
    network.
    but I don't know C.
    modified)
    own ideas
    Test and enjoy.
    Jarek Jasiewicz
    grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
Just tested in a LatLong region. works fine.
Carlos
2009/7/28 Jarek Jasiewicz <jarekj@amu.edu.pl>:
but it shoud work
Jarek
Hi Jarek
milton
Hi list!
dataset.
network.
but I don't know C.
modified)
own ideas
Test and enjoy.
Jarek Jasiewicz
_________________
Thanks Carlos!!
milton
2009/7/28 Carlos Grohmann <carlos.grohmann@gmail.com>
Carlos
try, I don’t know I haven’t LL location to test it
but it shoud work
Jarek
Hi Jarek
milton
2009/7/26 Jarek Jasiewicz <jarekj@amu.edu.pl mailto:[jarekj@amu.edu.pl](mailto:jarekj@amu.edu.pl)>
Hi list!
dataset.
network.
but I don’t know C.
modified)
own ideas
Test and enjoy.
Jarek Jasiewicz
grass-user@lists.osgeo.org mailto:[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
First, if I haven't said this yet, wonderful job. Is there a way to
extract things like total lengths of streams from the raster. Like
length of stream order 1, 2, etc., so that percentage of occurrence
could be calculated- length order1/length total? On an unrelated note
I added this package to the raster set in the source and recompiled on
Mac. I have lost the ability to use the python GUI. I am having a
hard time figuring out how to do this. Should I reinstall the Binary
version, add r.streams to the add on packages, or is there a simpler
way to add a flag in the ./configure argument?
Stephen Sefick
On Tue, Jul 28, 2009 at 11:14 AM, Milton Cezar
Ribeiro<miltinho.astronauta@gmail.com> wrote:
Thanks Carlos!!
milton
Carlos
> but it shoud work
> Jarek
>> Hi Jarek
>> milton
>> Hi list!
>> dataset.
>> network.
>> but I don't know C.
>> modified)
>> own ideas
>> Test and enjoy.
>> Jarek Jasiewicz
>> _______________________________________________
_________________
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
                -K. Mullis
stephen sefick pisze:
In the feature module is only introducion to full Hortonian analysis
Like
I don't know nothhing about wxGUI except that it exist so I cannot help.
Stephen Sefick
Thanks Carlos!!
milton
Carlos
but it shoud work
Jarek
Hi Jarek
milton
   Hi list!
   dataset.
   network.
   but I don't know C.
   modified)
   own ideas
   Test and enjoy.
   Jarek Jasiewicz
_________________
