I’ve been following GRASS-user discussion related with pos-classigfication, classification, aggregation and so on. But, while I was readingh those emails I figured that I will need to perform, before classification, an image segmentation to derive objects.
Can anyone give me a clue abvout that because in GRASS book, I only founded Image segmentation related with processing large quantities of vectorial data (DEM’s).
On Mon, Jan 18, 2010 at 6:30 PM, Nikos Dumakis <nikosdu1980@gmail.com> wrote:
Greetings all
I've been following GRASS-user discussion related with pos-classigfication,
You don't need to perform a segmentation before doing classification but
i.smap is doing it in a combined way.
data (DEM's).
(DEMs are raster data)
What you need to do is to prepare the statistics with i.gensigset. See
"radiometric & geometric supervised" in
You are absolutely right My mistake. SMAP is a segmentation algorithm. But my idea was not to use SMAP as a classification but use a Segmentation process and only then a Supervides Classification. Or if Use SMAP I’m doing both things in this order?
Thanks Markus
Nikos
On Mon, Jan 18, 2010 at 11:22 PM, Markus Neteler <neteler@osgeo.org> wrote:
Greetings all
You don’t need to perform a segmentation before doing classification but
data (DEM’s).
“radiometric & geometric supervised” in
Thanks Markus
Nikos
Greetings all
data (DEM’s).
Greetings all
data (DEM’s).
