[GRASS-user] average calculation
Seb wrote:
If one were to calculate an average of several rasters, one
could simply
do:
r.mapcalc "ave = (A + B + C) / 3"
But how can we get around the problem of null values in any of the
rasters, which would propagate it to the result? What is an efficient
way to calculate both the numerator and denominator for each pixel so
that it corresponds only to rasters with non-null values.
be careful with those sorts of tricks because different regions of the
result will end up with different levels of statistical strength and
so the result may be misleading.
A second problem is how to script this (shell) so that a large
number of rasters can be included in this calculation. I would
appreciate some pointers to some scripts where something along
these lines can be read, or any thoughts about alternative/better
approaches.
use r.series method=average. The -n flag will Propagate NULLs.
Hamish
On Wed, 13 May 2009 22:21:51 -0700 (PDT),
Hamish <hamish_b@yahoo.com> wrote:
Seb wrote:
If one were to calculate an average of several rasters, one could
simply do:
efficient way to calculate both the numerator and denominator for
each pixel so that it corresponds only to rasters with non-null
values.
A second problem is how to script this (shell) so that a large number
of rasters can be included in this calculation. I would appreciate
some pointers to some scripts where something along these lines can
be read, or any thoughts about alternative/better approaches.
Thanks Hamish, that's exactly the tool for this job. Basically,
r.series without the -n flag would do what I described, although the
point about uneven representation of cells across rasters is something
to worry about.
Seb
