Hi
I’m trying to run GRASS and import raster map using a bash script but I’m getting an error saying r.in.gdal not found.
What have I done wrong? see the script below.
#!/bin/sh
#variable to customize:
path to GRASS software main directory
GISBASE=/usr/bin/grass64
path to GRASS database
GISDBASE=$HOME/grassdem
GISBASELIB=/usr/lib/grass64
nothing to change below
MAP=SRTMDEM.tiff
LOCATION=/home/tgumede1/grassdem
generate temporal LOCATION:
TEMPDIR=Floods
mkdir -p $GISDBASE/$TEMPDIR/tmp
save existing $HOME/.grassrc6
if test -e $HOME/.grassrc6 ; then
mv $HOME/.grassrc6 /$GISDBASE/$TEMPDIR.grassrc6
fi
echo “LOCATION_NAME: $TEMPDIR” > $HOME/.grassrc6
echo “MAPSET:tmp” >> $HOME/.grassrc6
echo “DIGITIZER: none” >> $HOME/.grassrc6
echo “GISDBASE: $GISDBASE” >> $HOME/.grassrc6
export GISBASE=$GISBASE
first our GRASS, then the rest
export PATH=$GISBASE:$GISBASELIB/scripts:$PATH
first have our private libraries:
export LD_LIBRARY_PATH=$GISDBASE/lib:$GISBASELIB/lib:$LD_LIBRARY_PATH
import raster map into new location:
r.in.gdal -eo in=$MAP out=dem location=$LOCATION
if [$? -eq 1] ; then
echo “An error occured. Stop.”
exit 1
fi
restore saved $HOME/.grassrc6
fi
Kind Regards
TS Gumede
CSIR, Meraka Institute
072 258 1650
