Hi
...d.what.vect -1 -t map=lines|grep category|awk '{print $2}'>>cat.txt...
I compiled grass with NLS (national languages suports) and script stop working becouse there is no category (grep) but kategoria (category in polish). In my few scripts it is no problem (or rather I will never use NLS), but what about scripts in grass add-ons and nls?
If a script parses output which is meant to be human-readable, it
needs to explicitly set the locale to "C" for that command, e.g.:
> $2}'>>cat.txt...
> nls?
Glynn:
LC_ALL=C d.what.vect -1 -t ...
d.what.vect's -t specifically says it is for parsing:
-t Terse output. For parsing by programs
the i18n is not new, it's been there for 2.3 years. (but maybe the
translation is)
so a question: should std output intended for parsing be strictly
english only? (as debug messages are)
e.g. north: south: etc by g.region -p (not talking about g.region -g)
[-p is currently not translated]
> > nls?
Glynn:
Ah. Either the description is wrong, or the use of _(...) is a bug.
translation is)
If it's meant to be machine-readable, it shouldn't depend upon the
locale in any way.
I would say that -p output should be human-readable (if it isn't, then
how do you view the current region settings in a human-readable
form?).
Having said that, it wouldn't surprise me if there are a lot of
scripts which parse "g.region -p" output, so we would first need to
fix those to use -g instead.
