I have downloaded several sheets (approx 1600 files) from UK Ordnance
Survey open data web site in ESRI shapefile format and OS grid
references and now I need to convert them to MapInfo format and real
world co-ordinates.
I currently have available GRASS and Quantum GIS in linux and Mapinfo
4.1 & 5 running in windows emulation. Don't laugh, poverty dictates I
can't afford to update.
Does anyone know of a better solution than loading each shapefile into
QGIS then save as Mapinfo and keeping the OS grid ref.?
> Από: Mick bareman@tpg.com.au > Θέμα: [GRASS-user] batch conversion of ESRI to MapInfo > Προς: “grass user” grass-user@lists.osgeo.org > Ημερομηνία: Σάββατο, 29 Ιανουάριος 2011, 9:43 > > I have downloaded several sheets (approx 1600 files) from UK Ordnance > Survey open data web site in ESRI shapefile format and OS grid > references and now I need to convert them to MapInfo format and real > world co-ordinates. > > I currently have available GRASS and Quantum GIS in linux and Mapinfo > 4.1 & 5 running in windows emulation. Don’t laugh, poverty dictates I > can’t afford to update. > > Does anyone know of a better solution than loading each shapefile into > QGIS then save as Mapinfo and keeping the OS grid ref.? > > mik > _______________________________________________ > grass-user mailing list > grass-user@lists.osgeo.org > http://lists.osgeo.org/mailman/listinfo/grass-user
As suggested, better to use ogr2ogr.
if you use linux:
1- Create an empty text file in the folder where your shapefiles are
located
2- Open the text file and copy paste these:
mkdir ./mapinfo
for file in *.shp
do
ogr2ogr -f "MapInfo File" mapinfo/$file.tab $file
done
3-save the file as convert.sh
4- from the terminal, run convert.sh
$ cd /PATH/TO/SHAPEFILES/
$ sh convert.sh
5- all your mapinfo files should appear under mapinfo folder.
Sab
On Sat, 2011-01-29 at 09:15 +0000, Leonidas Liakos wrote:
What about using ogr2ogr?
ogr2ogr -f "MapInfo File" mapinfo.tab input.shp
You have to write a script for batch conversion.
--- Στις Σάβ., 29/01/11, ο/η Mick <bareman@tpg.com.au> έγραψε:
Ordnance
and real
world co-ordinates.
Mapinfo
dictates I
shapefile into
You could cut away the "shp" suffix like this:
ogr2ogr -f "MapInfo File" mapinfo/${file%shp}tab $file
I am not fully sure what "real world co-ordinates" means, but this additional switch might do what you expect:
-t_srs epsg:4326
Hermann
On 29/01/2011 10:53, Saber Razmjooei wrote:
Mik
if you use linux:
located
mkdir ./mapinfo
for file in *.shp
do
done
$ sh convert.sh
indeed!
cheers
Sab
-t_srs epsg:4326
Hermann
> Mik
> if you use linux:
> located
> mkdir ./mapinfo
> for file in *.shp
> do
> done
> $ sh convert.sh
> Cheers
> Sab
On Sat, 29 Jan 2011 14:37:34 +0000
indeed!
cheers
Sab
> -t_srs epsg:4326
> Hermann
> > Mik
> > if you use linux:
> > are located
> > mkdir ./mapinfo
> > for file in *.shp
> > do
> > done
> > $ sh convert.sh
> > Cheers
> > Sab
Many many thanks to those who offered their help, after most of the day
relearning a small chunk of bashing I now have my data converted.
