I'm a beginner in GRASS but hope to master it someday
it looks infinite in terms of possibilities
I'm trying to polygonize a raster.
this raster is in black and white.
I want to polygonize only the white parts of the image.
I noticed that r.to.vect had a -v option allowing to polygonize certain
parts of an image. Is it this option that I must use to vectorize the white
parts of my image? If yes, how can I use it? If not, how to manage the
operation?
operation?
use -v, but before that use r.mask, r.reclass, or r.mapcalc to make a MASK
map so only the white bits are visible to the r.to.vect module. After you
are done remember to remove or rename the MASK map
