Dear community
After installing GRASS GIS 8.3.2 (windows), setting all the correct paths to run rstudio within a GRASS GIS session (many thanks to the community!) and installing the addon r.boxplot, I was able to run part of the code in example 1
https://ecodiv.earth/post/drawing-boxplots-of-raster-values/
Great tool, I was able to produce the boxplot using GUI or the command line.
Example 1
# Import the required library
library(rgrass)
# Set the region and MASK
execGRASS(“g.region”, flags=“a”, vector=“TALregion”,
raster=“LAI300_20140920”)
execGRASS(“r.mask”, vector=“TALregion”)
However, I received the error message, that r.boxplot is not found. I tried to install r.boxplot via r package, however, there is no r.boxplot r package. Searching the GRASS GIS help, I am not aware of an additional code section for r.boxplot?
Kind regards
Sibylle
