[GRASS-user] bug with r.reclass
Dear All:
I am trying to use the grass i.atcor for atmospheric correcction. Would you give me a clue what the ‘‘text file’’ to be used asone of the input parameters and if possible the sample/format of the file. The dialogue window for input image does not seem to allow uploading the raster file. Any assistance is very much appreciated.
Best regards,
Asefa
---------- Forwarded message ----------
From: BLANDENIER Lucien <lucien.blandenier@unine.ch>
Date: Wed, May 15, 2013 at 5:04 PM
Subject: [GRASS-user] bug with r.reclass
To: “grass-user@lists.osgeo.org” <grass-user@lists.osgeo.org>
BLANDENIER Lucien (lucien.blandenier@unine.ch) is not on your Guest List | Approve sender | Approve domain
Dear all,
I’m facing a problem with r.reclass on GRASS 6.4.2 on Linux mint.
r.reclass seems to have a small bug.
I worked with output name “test” , but then, It didn’t work any more with others output names…
This the command I did:
r.reclass --overwrite input=input@mapset output=test rules=path
With the rules:
3 thru 7 = 1
  • = NUll
I received the following error when I tried to display the raster or to see the metadata (In french, sorry!):
It says that it is not possible to find the history of the file and to read the boundary file (or limit file)
(Wed May 15 15:28:43 2013)
r.info map=DFO_2006203_LorianSwampsArea_reclass@Merti_Flood_Events_2006_2008_2011
impossible d’obtenir l’historique pour [DFO_2006203_LorianSwampsArea_reclass@Merti_Flood_Events_2006_2008_2011] dans le mapset [Merti_Flood_Events_2006_2008_2011]
impossible de lire le fichier de limites pour [DFO_2006203_LorianSwampsArea_reclass@Merti_Flood_Events_2006_2008_2011 dans Merti_Flood_Events_2006_2008_2011]
ERROR: Unable to read range file
(Wed May 15 15:28:43 2013) La commande s’est terminée (0 sec)
Commande ‘d.rast’ échouée. Détails : impossible de lire le
[DFO_2006203_LorianSwampsArea_reclass dans
Do someone has an idea what the problem is ?
Regards
Lucien
grass-user mailing list
Asefa Teferi Areda
MSc student Centre for Geo information and Remote Sensing
Wageningen University
Bornsesteeg1 3c 5
6708GA Wageningen
The Netherlands
E-mail: moybonat2u@gmail.com
Mobile: +31644565064
Asefa Areda wrote:
Dear All:
give me a clue what the ''text file'' to be used asone of the input
Dear Asefa,
please use a proper subject title when mailing to the list -- otherwise, your
mail might get "lost" and maybe not read at all.
Besides the manual of i.atcorr itself
<http://grass.osgeo.org/grass64/manuals/i.atcorr.html&gt;, you might want to have
a look in the respecti GRASS wiki page (and section)
<http://grasswiki.osgeo.org/wiki/Atmospheric_correction#Atmospheric_correction&gt;\.
This two sources should help.
Best, Nikos
