I have got a SRTM tile and I built the contour lines with r.contour
then I tried e.g. r.surf.contour or to export closed polygons, but I am not confident with the results..
I am looking for a hint to find an efficient way to extract the areas between contour lines which have no boundaries...(?)
perhaps just adding boundaries could be a solution and export closed polygons after this... (?) - closing them by hand takes too much time. Perhaps there is a command to add boundaries to a given region.
On Wed, Feb 3, 2010 at 11:55 AM, "Kilian Schönberger" <KiSchoe@gmx.de> wrote:
Hello,
You mean to interpolate the pixels between the contour lines
(so: from vector contours to raster map) or to insert additional
contour lines?
