Greetings
I have a map with values and a base map created with r.clump. How can I calculate the average of values that falls inside each cluster defined by r.clump?
Thanks
Best regards,
Monica
Greetings
Thanks
Best regards,
Monica
Monica,
try to use r.statistics with the average function/method. Pass you maps through the cover= and base= parameters…
Christian.
Sent: Monday, February 28, 2011 4:27 PM
To: GRASS user list
Subject: [GRASS-user] calculating average value over a base map
Greetings
Thanks
Best regards,
Monica
grass-user mailing list
grass-user@lists.osgeo.org
Greetings Christian
Unfortunely it only works with CELL values. For instance, r.median uses more than just CELL.
Is there any other alternative? Beucase for mode and median there is specific functions.
Thamls
Best regards,
Monica
On Mon, Feb 28, 2011 at 3:55 PM, Christian Schwartze <christian.schwartze@uni-jena.de> wrote:
Monica,
Christian.
To: GRASS user list
Subject: [GRASS-user] calculating average value over a base mapGreetings
ThanksBest regards,
Monica
If you want to deal with raster value types other than CELL, you can use the –c flag in r.statistics in order to process the labels. Therfore, you have to copy your cat values to the category labels first…
Christian.
Sent: Monday, February 28, 2011 5:16 PM
To: Christian Schwartze
Cc: GRASS user list
Subject: Re: [GRASS-user] calculating average value over a base map
Greetings Christian
Thamls
Best regards,
Monica
Monica,
Christian.
To: GRASS user list
ThanksBest regards,
Monica
Hello Christian.
I believe I didn’t quite understand what you have said but I think that is not the way.
My basemap is a r.clump output in CELL format that ranges from 1 til 1700 or something
my cover map is NDVI that ranges from -1 (near) til 1 (near) and is a FCELL.
My Objective. calculate for each clump, the average of NDVI pixels
If I do:
r.statistics -c base=new_clump cover=2007_ndvi method=average
I get:
ERROR: This module currently only works for integer (CELL) maps
Is there any alternative to do this?
Thank you Christian and the rest of grass mailing list
Monica
On Mon, Feb 28, 2011 at 5:08 PM, Christian Schwartze <christian.schwartze@uni-jena.de> wrote:
Christian.From: Monica Buescu
Cc: GRASS user list
Subject: Re: [GRASS-user] calculating average value over a base mapGreetings Christian
Is there any other alternative? Beucase for mode and median there is specific functions.Thamls
Best regards,
MonicaOn Mon, Feb 28, 2011 at 3:55 PM, Christian Schwartze <christian.schwartze@uni-jena.de> wrote:
Monica,
Christian.
To: GRASS user list
ThanksBest regards,
Monica
Hi DmistrijI think it was worked. I just need to figure out something with r.statistics.
Thanks
Monica
Monica,
I did similar things on slope values…have a look to the following code snippet:
r.mapcalc slope_mult=int(slope1000.0)
r.stats -nN input=slope_mult | awk ‘{print $1"=“$1” "$1/1000}’ | r.reclass --o input=slope_mult output=slope_labeled
r.statistics --o -c base=base_map cover=slope_labeled method=average output=slope_avg
r.mapcalc slope_avg_cval=int(@slope_avg1000)/1000.0
Perhaps it may help you…
Christian.
Sent: Tuesday, March 01, 2011 11:40 AM
To: Dmitrij Kolesov ; GRASS user list
Thanks
Monica
