Dear Niels,
r.albedo is now i.albedo, few days back it has been moved from
AddonsSVN to mainSVN of GRASS.
I.evapo.potrad is the potential evapotranspiration from incoming sun
radiation, meaning non-water stressed ET. It would be useless in areas
where there is any water stress like a desert.
i.evapo.SENAY refers to a simple water stress estimation based on
temperature from satellite. This has proven useful by Senay (2007)
while mapping the whole of Afghanistan at once. We found limitations
when dealing with small areas.
i.eb.evapfr is certainly going to push you further into water stress
sensitivity anaylsis, but for that you'll need to use many GIPE
modules, this is why there is a script_generator/ in GIPE directory,
it will automatize the set up of all of the modules function into an
easy script to perform several evapotranspiration mapping under
various water stress estimation systems (various models are in GIPE:
i.eb.h_SEBAL95/01, i.eb.h_iter, etc...). However, the script generator
is not updated to the latest changes I had to make to integrate those
GIPE modules into the main GRASS SVN. So you'll need to run the script
generator, and then run the lines one by one to check the changes
according to your set up. Once the GIPE modules are integrated into
main GRASS, I'll update the script_generator.
i.dn2full.l5/7 generates top of atmosphere radiative temperature. You
will still need to pull out a correction to get the radiative
temperature corrected to skin surface temperature. In very clear and
dry conditions, there should be very less correction to make.
Transmissivity of the atmosphere is an efficiency factor [0-1] that
expresses the loss of radiation from 100% arriving at top of
atmosphere. Single-way transmissivity, is a one-way ticket either from
top of atmosphere to the skin surface of the Earth or from the skin
surface of the Earth to the Top of Atmosphere. Try 0.7 for a start if
you do not have cloudiness indices or Angstrom equation
parameterization locally.
Yann
2008/9/29 Niels Thevs <thevs@uni-greifswald.de>:
Dear Yann Chemin,
have many thanks for your reply regarding i.dn2full.l5/17:
The background of my question was that we want to calculate
evapotranspiration from desert and semi desert areas. According to your and
other users' experience, which add on performs better: i.evapo.potrad,
i.evapo.senay, or i.eb.evapfr ?
Regarding the required input parameter for i.evapo.potrad and i.evapo.senay,
can I use r.albedo and where do I find it ? Can I derive the surface skin
temperature through i.dn2full.l5/17 ? I was wundering because in the
description for i.dn2full.l5/17 there was written that DN is calculated into
radiance at top of the athmosphere. Furthermore, what is the single way
transmissivity ?
Best regards
Niels
Yann Chemin schrieb:
Hi Niels,
in grass-Addons/gipe/ there are a couple of functions to get L1b
Landsat 5/7 into radiant temperature at top of atmosphere.
i.dn2full.l5
i.dn2full.l7
this corrects standard images having .met standard metadata file or
NLAPS metadata (.txt) file.
You may try and see if you get to some useful ends.
You may also see some fast method to get surface temperature from this
product by using emissivity. As it was used for AVHRR 15 years ago.
in Grass-Addons, i.landsat.toar may also help you out, but it is a
long time I have had a look at it.
Yann
2008/9/25 Niels Thevs <thevs@uni-greifswald.de>:
Dear Grass users,
does anybody have experience with the calibration of the Landsat thermal
data ? I have a few ground measurements of temperature (air temperature
in 2
m above surface) and want to relate them to a corresponding Landsat image
(band 6). In the papers which I read there are listed a lot of working
steps
like calibration for at sensor radiance, surface radiance, etc. Is it
necessary to do all those steps or does anybody know a more simple
algorithm
Best regards
Niels
Dr. Niels Thevs
Chair of Geobotany and Landscape Ecology
Institute of Botany and Landscape Ecology
Greifswald University
Grimmer Strasse 88
17487 Greifswald
Germany
Tel.: +49-3834-86-4137
Fax: +49-3834-86-4114
grass-user mailing list
grass-user@lists.osgeo.org
Dr. Niels Thevs
Grimmer Strasse 88
17487 Greifswald
Germany
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
