[GRASS-user] Cannot pull from dev master branch
I've not used grass in a long time and want to update my source code to the
current dev status as I've done before. But, there's a merge issue I need to
learn how to resolve. My attempt:
$ git pull
error: Your local changes to the following files would be overwritten by merge:
   Dockerfile
   contributors.csv
   display/d.legend.vect/draw.c
   doc/development/submitting/python.md
   doc/development/submitting/submitting.md
   doc/development/submitting/submitting_c.md
   doc/gui/wxpython/example/frame.py
   doc/infrastructure.md
   doc/python/raster_example_ctypes.py
   docker/alpine/Dockerfile
   docker/alpine/Dockerfile_alpine_latest
   docker/debian/Dockerfile
   docker/ubuntu/Dockerfile
   docker/ubuntu_wxgui/Dockerfile
   gui/wxpython/animation/nviztask.py
   gui/wxpython/animation/temporal_manager.py
   gui/wxpython/core/gconsole.py
   gui/wxpython/core/globalvar.py
   gui/wxpython/core/menutree.py
   gui/wxpython/core/settings.py
   gui/wxpython/core/toolboxes.py
   gui/wxpython/core/utils.py
   gui/wxpython/core/workspace.py
   gui/wxpython/core/ws.py
   gui/wxpython/datacatalog/tree.py
   gui/wxpython/dbmgr/base.py
   gui/wxpython/dbmgr/dialogs.py
   gui/wxpython/dbmgr/sqlbuilder.py
   gui/wxpython/gcp/manager.py
   gui/wxpython/gmodeler/frame.py
   gui/wxpython/gmodeler/model.py
   gui/wxpython/gui_core/dialogs.py
   gui/wxpython/gui_core/forms.py
   gui/wxpython/gui_core/gselect.py
   gui/wxpython/gui_core/mapdisp.py
   gui/wxpython/gui_core/preferences.py
   gui/wxpython/gui_core/prompt.py
   gui/wxpython/gui_core/pyedit.py
   gui/wxpython/gui_core/treeview.py
   gui/wxpython/gui_core/vselect.py
   gui/wxpython/gui_core/widgets.py
   gui/wxpython/iclass/dialogs.py
   gui/wxpython/iclass/frame.py
   gui/wxpython/iclass/statistics.py
   gui/wxpython/iclass/toolbars.py
   gui/wxpython/icons/icon.py
   gui/wxpython/image2target/ii2t_manager.py
   gui/wxpython/iscatt/controllers.py
   gui/wxpython/iscatt/core_c.py
   gui/wxpython/iscatt/dialogs.py
   gui/wxpython/iscatt/frame.py
   gui/wxpython/iscatt/iscatt_core.py
   gui/wxpython/iscatt/plots.py
   gui/wxpython/iscatt/toolbars.py
   gui/wxpython/lmgr/frame.py
   gui/wxpython/lmgr/giface.py
   gui/wxpython/lmgr/layertree.py
   gui/wxpython/lmgr/statusbar.py
   gui/wxpython/lmgr/workspace.py
   gui/wxpython/location_wizard/wizard.py
   gui/wxpython/main_window/frame.py
   gui/wxpython/mapdisp/frame.py
   gui/wxpython/mapdisp/main.py
   gui/wxpython/mapswipe/frame.py
   gui/wxpython/mapwin/base.py
   gui/wxpython/mapwin/buffered.py
   gui/wxpython/modules/colorrules.py
   gui/wxpython/nviz/mapwindow.py
   gui/wxpython/nviz/tools.py
   gui/wxpython/nviz/wxnviz.py
   gui/wxpython/photo2image/ip2i_manager.py
   gui/wxpython/psmap/dialogs.py
   gui/wxpython/psmap/frame.py
   gui/wxpython/psmap/instructions.py
   gui/wxpython/startup/guiutils.py
   gui/wxpython/tools/build_modules_xml.py
   gui/wxpython/vdigit/mapwindow.py
   gui/wxpython/vdigit/toolbars.py
   gui/wxpython/vdigit/wxdigit.py
   gui/wxpython/vdigit/wxdisplay.py
   gui/wxpython/vnet/dialogs.py
   gui/wxpython/vnet/vnet_core.py
   gui/wxpython/vnet/vnet_data.py
   gui/wxpython/vnet/widgets.py
   gui/wxpython/web_services/dialogs.py
   gui/wxpython/web_services/widgets.py
   gui/wxpython/wxgui.py
   gui/wxpython/wxplot/base.py
   imagery/i.atcorr/geomcond.cpp
   imagery/i.atcorr/i.atcorr.html
   lib/bitmap/bitmap.c
   lib/init/grass.py
   lib/vector/Vlib/area.c
   lib/vector/Vlib/buffer2.c
   lib/vector/Vlib/build.c
   lib/vector/Vlib/build_sfa.c
   lib/vector/Vlib/close.c
   lib/vector/Vlib/copy.c
   lib/vector/Vlib/field.c
   lib/vector/Vlib/header.c
   lib/vector/Vlib/level_two.c
   lib/vector/Vlib/line.c
   lib/vector/Vlib/net_analyze.c
   lib/vector/Vlib/open.c
   lib/vector/Vlib/poly.c
   lib/vector/Vlib/read.c
   lib/vector/Vlib/read_ogr.c
   lib/vector/Vlib/simple_features.c
   lib/vector/Vlib/write.c
   lib/vector/Vlib/write_nat.c
   lib/vector/Vlib/write_pg.c
   locale/grass_po_stats.py
   locale/po/grasslibs_ar.po
   locale/po/grasslibs_bn.po
   locale/po/grasslibs_cs.po
   locale/po/grasslibs_de.po
   locale/po/grasslibs_el.po
   locale/po/grasslibs_es.po
   locale/po/grasslibs_fi.po
   locale/po/grasslibs_fr.po
   locale/po/grasslibs_hu.po
   locale/po/grasslibs_id_ID.po
   locale/po/grasslibs_it.po
   locale/po/grasslibs_ja.po
   locale/po/grasslibs_ko.po
   locale/po/grasslibs_lv.po
   locale/po/grasslibs_ml.po
   locale/po/grasslibs_pl.po
   locale/po/grasslibs_pt.po
   locale/po/grasslibs_pt_BR.po
   locale/po/grasslibs_ro.po
   locale/po/gra
Aborting
Please advise me how to resolve this issue so I can keep sync'd with the
source repo.
TIA,
Rich
On Fri, 24 Nov 2023, Linda Karlovská wrote:
you can do the following in your main branch:
Linda,
git checkout main
$ git checkout main
Already on 'main'
Your branch and 'origin/main' have diverged,
and have 81 and 186 different commits each, respectively.
   (use "git pull" to merge the remote branch into yours)
git fetch upstream
$ git fetch upstream
fatal: 'upstream' does not appear to be a git repository
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
Instead,
$ git fetch $ git reset --hard
HEAD is now at 8968e9b631 Merge branch 'main' of https://github.com/OSGeo/grass
The log confirms this.
Many thanks,
Rich
If there are no changes you want to keep, just git reset --hard HEAD.
Māris.
piektd., 2023. g. 24. nov., plkst. 16:13 — lietotājs Rich Shepard via
grass-user (<grass-user@lists.osgeo.org>) rakstīja:
$ git pull
        Dockerfile
        contributors.csv
        lib/bitmap/bitmap.c
        lib/init/grass.py
        locale/po/gra
Aborting
source repo.
TIA,
Rich
grass-user mailing list
Māris,
Thank you. My use of git is quite simple so there's much I don't know.
Rich
