I have a GeoTIFF that I can read in to a raster. ~r.info~ reports "max = inf". If I try to write it out as a raster with ~r.out.gdal~ I get an error (below) and the file is not saved to disk. I can't figure out how to replace "inf" values with ~r.mapcalc~. Can someone suggest how to work with this data?
-k.
Checking GDAL data type and nodata value...
100%
WARNING: Selected GDAL datatype does not cover data range.
WARNING: GDAL datatype: Float32, range: -3.4e+38 - 3.4e+38
WARNING: Raster map <foo> range: 0.393347 - inf
WARNING: Raster export results in data loss.
Using GDAL data type <Float32>
Input raster map contains cells with NULL-value (no-data). The value nan
will be used to represent no-data values in the input map. You can specify
a nodata value with the nodata option.
ERROR: Raster export aborted.
On Sat, Nov 11, 2017 at 12:25 AM, Ken Mankoff <mankoff@gmail.com> wrote:
Dear GRASS list,
Can you please post the output of
gdalinfo -mm your_raster_map
Sounds like "unusual"...
That is likely a error due to above problem.
-k.
100%
grass-user mailing list
grass-user@lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/grass-user
Dear GRASS list,
I have a GeoTIFF that I can read in to a raster. ~r.info~ reports “max = inf”. If I try to write it out as a raster with ~r.out.gdal~ I get an error (below) and the file is not saved to disk. I can’t figure out how to replace “inf” values with ~r.mapcalc~. Can someone suggest how to work with this data?
-k.
Checking GDAL data type and nodata value…
100%
Did you specify type=Float32? If yes, try to use type=Float64. You can also use the -f flag to force raster export.
Markus M
WARNING: Raster map range: 0.393347 - inf
-f doesn't solve this. Exact same error except the valid data range has changed:
I can post the full output, but I assume the part you are interested is the diff between the normal and the '-mm' option, which is:
Computed Min/Max=0.380,inf
Which are the values reported by ~r.info~.
It may be a bug with the upstream producer. If inf is invalid, I can let them know. I have not seen mention of inf anywhere online (searching GeoTIFF, GDAL, or GRASS), but it makes it hard to search because INF is a file format.
inf is a perfectly valid number, meaning infinity. Unfortunately, a test for inf is only available with C standard 99, and I don’t know of a manual test in C for inf (or -inf) to avoid C 99. The bug is in r.out.gdal, not testing for input inf values.
Markus M
On 2017-11-11 at 11:49, Markus Metz <markus.metz.giswork@gmail.com> wrote:
inf values are now exported with r.out.gdal in trunk and relbr72
(r71665,6).
Great news. Thanks for fixing this bug. Is there any way to process/detect these numbers in r.mapcalc until the bugfix makes its way into a packaged distribution?
(r71665,6).
It seems that r.mapcalc treats inf as nan (NULL cells), so r.mapcalc probably does not help.
I figured out a solution: r.null map=foo setnull=inf
