[GRASS-user] Clarifying 'no' comments post configuration
I've installed GRASS 6.4.2 and wanted to check if the the features indicated
by 'no' are no longer supported/deprecated?
BLAS support: no
DWG support: no
GLw support: no
Richard
GRASS is now configured for: i686-pc-linux-gnu
  Source directory: /home/rcooper/Downloads/grass642/grass-6.4.2
  Build directory: /home/rcooper/Downloads/grass642/grass-6.4.2
  Installation directory: ${prefix}/grass-6.4.2
  Startup script in directory: ${exec_prefix}/bin
  C compiler: gcc -g -O2
  C++ compiler: c++ -g -O2
  Building shared libraries: yes
  64bit support: no
  OpenGL platform: X11
  MacOSX application: no
  MacOSX architectures:
  MacOSX SDK:
  Tcl/Tk NVIZ: yes
  BLAS support: no
  C++ support: yes
  Cairo support: yes
  DWG support: no
  FFMPEG support: yes
  FFTW support: yes
  FreeType support: yes
  GDAL support: yes
  GEOS support: yes
  GLw support: no
  JPEG support: yes
  LAPACK support: yes
  Large File support (LFS): yes
  Motif support: yes
  MySQL support: no
  NLS support: yes
  ODBC support: no
  OGR support: yes
  OpenGL support: yes
  PNG support: yes
  PostgreSQL support: yes
  Python support: yes
  Readline support: yes
  SQLite support: yes
  Tcl/Tk support: yes
  wxWidgets support: yes
  TIFF support: yes
  X11 support: yes
View this message in context: http://osgeo-org.1560.n6.nabble.com/Clarifying-no-comments-post-configuration-tp4708286p4708286.html
You need to switch it on in the configure step:
BLAS support: no
--with-blas
DWG support: no
--with-opendwg
GLw support: no
--with-glw
There are the respective switches:
  --with-XXX-includes=DIRS
  --with-XXX-libs=DIRS
if needed.
Note that BLAS is almost unused (only on gmath lib). And v.in.dwg is
likely outdated for the latest OpenDWG libraries. There is a related
Addon available.
Hope this helps
BLAS support: no
Adds additional functionality to the gmath library. Nothing in GRASS
currently uses that functionality.
DWG support: no
Required for v.in.dwg, which also requires the OpenDWG library, which
isn't free software.
GLw support: no
Required for r3.showdspf, which also requires Motif.
