[GRASS-user] Compilation error with g.extension v.krige
Dear all,
I’m trying to install v.krige via g.extension v.krige but I receive an error.
My configurations are the followings:
GRASS version: 6.4.3
GRASS SVN Revision:
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.10.0
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Linux-3.8.0-31-generic-x86_64-with-Ubuntu-13.04-raring
Below the last lines of the command output:
Alessandro Sarretta
e-mail: [alessandro.sarretta@gmail.com](mailto:alessandro.sarretta@gmail.com)
skype: alesarrett
Web: [http://ilsarrett.wordpress.com](http://ilsarrett.wordpress.com)
Twitter: [https://twitter.com/alesarrett](https://twitter.com/alesarrett)
Google scholar: [http://scholar.google.it/citations?hl=it&user=IsyXargAAAAJ](http://scholar.google.it/citations?hl=it&user=IsyXargAAAAJ)
ORCID: [http://orcid.org/0000-0002-1475-8686](http://orcid.org/0000-0002-1475-8686)
ResearchGate: [https://www.researchgate.net/profile/Alessandro_Sarretta/](https://www.researchgate.net/profile/Alessandro_Sarretta/)
Hi Alessandro,
On Thu, Oct 17, 2013 at 11:30 AM, Alessandro Sarretta <
alessandro.sarretta@gmail.com> wrote:
Dear all,
I'm trying to install v.krige via *g.extension v.krige* but I receive an
error.
GRASS version:
6.4.3
GRASS SVN
Revision:
(2012-02-25)
GDAL/OGR:
1.10.0
2012
Python:
2.7.4
wxPython:
2.8.12.1
/usr/bin/install: target
‘/home/ale/Documents/grassdb/wgs84/PERMANENT/.tmp/sarretta-utos/32627.0/dist.x86_64/etc/wxpython/scripts/’
is not a directory: No such file or directory**
**make: *** [default] Error 1**
**ERROR: Compilation failed, sorry. Please check above error messages.**
I've read this
http://lists.osgeo.org/pipermail/grass-user/2011-April/060329.html
but I can't understand whether it is related with my problem or not.
Do you have any ideas?
Thank you very much for any suggestion!
I got the same error on GRASS 6.4 when I tried to install v.krige. As an
interim fix, you might consider running the trunk version of GRASS 7 as
v.krige is available there.
best regards,
Daniel
Hi Alessandro,
On Thu, Oct 17, 2013 at 11:30 AM, Alessandro Sarretta <alessandro.sarretta@gmail.com> wrote:
Dear all,
error.
GRASS SVN Revision:
GDAL/OGR: 1.10.0
Python: 2.7.4
wxPython: 2.8.12.1
I have fixed the Makefile of v.krige for this. Should be fine as of r58031.
Please try again
g.extension v.krige
(and let us know)
thank you, very much now g.extension v.krige works fine! But when I try v.krige I have this error: I’m still using GRASS 6.4.3. Should I try to use GRASS 7 in trunk? Thanks again Ale
Hi Markus,
Please try again
g.extension v.krige
(and let us know)
Loading packages, please wait…
Attaching package: ‘XML’
The following object(s) are masked from ‘package:tools’:
toHTML
GRASS GIS interface loaded with GRASS version: GRASS 6.4.3 (2013)
and location: wgs84
Checking rgeos availability: TRUE
File “/home/ale/.grass6/addons/v.krige”, line 422, in
main()
File “/home/ale/.grass6/addons/v.krige”, line 309, in main
import globalvar
ImportError: No module named globalvar
Alessandro Sarretta
skype: alesarrett
