[GRASS-user] compilation problems with libiconv
Hello List
I am having some problems compiling grass 6.2.1. There seems to be some issue
with iconv on my ubuntu 6.06 system.
My configure:
./configure --with-cxx --with-jpeg --with-tiff --with-png --with-tcltk --with-postgres --with-opengl --with-fftw --with-motif --with-freetype --with-readline --with-curses --with-gdal=/usr/local/bin/gdal-config --with-tcltk-includes=/usr/include/tcl8.3 --with-tcltk-libs=/usr/lib --with-postgres-includes=/usr/include/postgresql --with-postgres-libs=/usr/lib --with-freetype-includes=/usr/include/freetype2 --with-freetype-libs=/usr/lib --with-proj-includes=/usr/include/ --with-proj-libs=/usr/lib --with-proj-share=/usr/share/proj
configure says:
checking for iconv.h... yes
checking for iconv... yes
so it seems to find something with iconv on my system. But when make finishes,
I get a list of modules where errors occured:
Errors in:
/home/frank/download/grass/grass-6.2.1/display/drivers/PNG
/home/frank/download/grass/grass-6.2.1/display/drivers/XDRIVER
/home/frank/download/grass/grass-6.2.1/display/d.ask
/home/frank/download/grass/grass-6.2.1/display/d.barscale
/home/frank/download/grass/grass-6.2.1/display/d.colorlist
/home/frank/download/grass/grass-6.2.1/display/d.colors
... and so on.
changing into one of these directories and running make gives me an error
similar to
/home/frank/download/grass/grass-6.2.1/dist.i686-pc-linux-gnu/lib/libgrass_driver.so:
undefined reference to `libiconv'
collect2: ld gab 1 als Ende-Status zurück
make[1]: ***
[/home/frank/download/grass/grass-6.2.1/dist.i686-pc-linux-gnu/etc/mon.list]
Fehler 1
make[1]: Verlasse
Verzeichnis '/home/frank/download/grass/grass-6.2.1/display/d.mon/pgms'
iconv is installed in /usr/local/bin, /usr/local/lib and /usr/local/include.
Does anybody have a idea what the issue might be? Looking into google and the
newsgroups didn't bring anything useful for me so I considered writing this
email.
I appreciate any help
Frank
Did you try to install libpng ?
Y.
Le Mardi 16 Janvier 2007 08:41, Frank Broniewski a écrit :
Hello List
issue with iconv on my ubuntu 6.06 system.
My configure:
configure says:
finishes, I get a list of modules where errors occured:
Errors in:
... and so on.
similar to
driver.so: undefined reference to `libiconv'
make[1]: ***
] Fehler 1
make[1]: Verlasse
/usr/local/include.
the newsgroups didn't bring anything useful for me so I considered writing
this email.
Frank
grassuser mailing list
grassuser@grass.itc.it
Yves Jacolin
http://yjacolin.gloobe.org
yes, libpng and the development files are installed. But I don't see the link
between libpng and iconv (character encoding).
Am Dienstag, 16. Januar 2007 10:09 schrieb Yves Jacolin:
Y.
> Hello List
> My configure:
> configure says:
> Errors in:
> ... and so on.
> similar to
>s_ driver.so: undefined reference to `libiconv'
> make[1]: ***
>st ] Fehler 1
> make[1]: Verlasse
> /usr/local/include.
> writing this email.
> Frank
make[1]: ***
Fehler 1
make[1]: Verlasse
email.
I strongly suspect that the problem is due to having two incompatible
iconv implementations on your system. Note that GNU libc has iconv
built in, so there shouldn't be any reason to have a separate iconv
implementation installed.
Depending upon the implementation, iconv_open(), iconv(), and
iconv_close() can be either functions or macros. If they are macros,
the actual functions will be called libiconv_open(), libiconv() and
libiconv_close(). If you end up using the headers from a version which
uses macros along with a library from a version which doesn't use
macros, you will get the above error. The implementation in GNU libc
doesn't use macros.
The configure script first checks for iconv() with no additional
libraries. It only checks for additional libraries and or libiconv()
if the first check fails. If you have GNU libc, the first check will
succeed, and no additional libraries will be requested (i.e. it won't
add -liconv when linking).
However, when compiling, the "#include <iconv.h>" will pick up the
version in /usr/local/include, which defines iconv() etc as macros
which call libiconv() etc, but as you aren't linking against libiconv,
those functions won't be found.
If you're determined to use a stand-alone libiconv, you will need to
manually edit the definition of ICONVLIB in include/Make/Platform.make
to:
  ICONVLIB = -L/usr/local/lib -liconv
after running configure but before compiling.
But I recommend that you simply remove the separate libiconv
implementation from your system. It doesn't provide any functionality
beyond that already provided by GNU libc.
Thanks alot! Removing the "local" iconv from my system did the trick. I don't
even remember correctly why I installed it, but I suspect problems with the
umn mapserver compilation. Well, doesn't matter anymore. Thanks alot again.
Am Dienstag, 16. Januar 2007 18:55 schrieben Sie:
>s_driver.so: undefined reference to `libiconv'
> make[1]: ***
>st] Fehler 1
> make[1]: Verlasse
> /usr/local/include.
> writing this email.
doesn't use macros.
to:
Softwaredienstleistungen
Frank Broniewski
Cloefstraße 76a
66693 Mettlach
Email: frank@geo-dienstleistung.de
WWW: http://www.geo-dienstleistung.de/
Telefon: 06865 / 911 040
