[GRASS-user] Compile module with different name
I need to keep an older copy of v.buffer, one that maintains the debug=buffer capability - I use this to retain overlaps as distinct polygons (instead of having two overlapping buffers merged into one).
So, what I would like to do is recompile the old v.buffer, but do so with the output as a different name - eg, v.oldbuffer.
How would I do this?
Cheers all,
Richard
2009/7/31 Richard Chirgwin <rchirgwin@ozemail.com.au>:
just change PGM variable in Makefile, e.g.
PGM = v.oldbuffer
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Martin Landa wrote:
PGM = v.oldbuffer
Martin
Martin and Janek,
Thanks, but not successful. Unfortunately, v.buffer won't make. The errors:
>main.c:214: error: too many arguments to function 'Vect_build_partial'
>main.c:215: error: too many arguments to function 'Vect_build'
>main.c: in function 'main':
>main.c.572: error: too many arguments to function 'Vect_build_partial'
>main.c.584: error: too many arguments to function 'Vect_snap_lines'
>main.c.587: error: too many arguments to function 'Vect_break_lines'
>main.c.590: error: too many arguments to function 'Vect_remove_duplicates'
>main.c.602: error: too many arguments to function 'Vect_build_partial'
>main.c.710: error: too many arguments to function 'Vect_build_partial'
This takes things beyond my limited programming skills. My issue is that I really need to be able to work with a "dirty" buffer.
Richard
the reason is that API has been slightly changed in grass64+ (messages
are printed in the standard way using G_message()). Just remove the
second argument from the functions (NULL, stdout/stderr). E.g.
Vect_build(&Map, stderr);
to
Vect_build(&Map);
Martin
Martin Landa wrote:
to
Vect_build(&Map);
Martin
Martin,
Thanks, I'll let you know how it goes ...
Richard
Martin Landa wrote:
to
Vect_build(&Map);
Martin
Martin,
Nailed it. Thanks!
Richard Chirgwin
