Hello there,
I just realize I've used r.composite for ages without wondering how I
could perform the reverse task. The thing is I ran r.composite on a 3
band geotiff orthoimage, dropped the initial .red, .green and .blue
rasters, and I would need them now in order to run r.out.vtk with the
rgbmaps argument. Dummy...
A quick glance at the composite raster color table makes me think it
might be quite easy to do. Is there a command for this opération or
should I try to write a script to do the job ?
Thank you,
Vincent
On Mon, Nov 25, 2013 at 7:22 AM, Vincent Bain <bain@toraval.fr> wrote:
Hello there,
You can use the # operator of r.mapcalc:
r.mapcalc "map.red = r#map"
r.mapcalc "map.green = g#map"
r.mapcalc "map.blue = b#map"
Markus M
Thank you,
Vincent
grass-user mailing list
grass-user@lists.osgeo.org
Thank you much Markus,
never noticed this mapcalc operator before, great !
Vincent
> Hello there,
Markus M
> Thank you,
> Vincent
Note that GRASS 7 has the r.rgb script which does just this.
Also, note that an r.composite+r.rgb round-trip normally loses
accuracy. By default, the maps generated by r.composite only use 32
levels for each component (equivalent to a 15-bpp image).
You can avoid this with "r.composite ... levels=256", but the
resulting maps will have much larger colour tables (65536 rules rather
than 1024), which can make certain operations significantly slower.
OK for the caution Glynn,
for my particular concern I finally re-ran the process from the source
files.
Thank you,
V.
