[GRASS-user] connect to postgreSQL
I have problem to connect to postgreSQL server from grass.
GRASS 6.3.0 (opava):~ > psql -l
        List of databases
   Name | Owner | Encoding
gis1 | bekas | UTF8
postgres | postgres | UTF8
template0 | postgres | UTF8
template1 | postgres | UTF8
(4 rows)
GRASS 6.3.0 (opava):~ > db.connect driver=pg database=gis1
GRASS 6.3.0 (opava):~ > db.test test=test1
create table grass_test1 (i1 integer, d1 double precision, c1 varchar(20))
DBMI-Postgres driver error:
Cannot connect to Postgres: could not connect to server: No such file or directory
  Is the server running locally and accepting
  connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
ERROR: Unable to open database <gis1>
ERROR: EXECUTE: ******** ERROR ********
etc.
I use PostgreSQL 8.3.3.
Don't you have an idea why it is not working?
Best regards,
Stanislav
On 04/10/08 16:39, Stanislav Bek wrote:
        List of databases
   Name | Owner | Encoding -----------+----------+----------
gis1 | bekas | UTF8
(4 rows)
etc.
The error message is quite clear:
"could not connect to server: No such file or directory
    connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?"
This is a PostgreSQL issue (you will probably get the same message if you try to connect with 'psql -h localhost gis1').
This means that PostgreSQL is not installed to accept connections via tcp/. You can change that in the relevant config file (probably something like /etc/postgresql/8.3/main/postgresql.conf - but that depends on your distribution).
Moritz
GRASS 6.3.0 (opava):~> psql -l
        List of databases
gis1 | bekas | UTF8
(4 rows)
GRASS 6.3.0 (opava):~> db.connect driver=pg database=gis1
GRASS 6.3.0 (opava):~> db.test test=test1
in the error said, the server is running locally..
Try
GRASS 6.3.0 (opava):~> db.connect driver=pg database="host=localhost,dbname=gis1"
db.login user=your user pass=your password
db.connect -p
db.tables -p
if not is connection posible. follow you the advice Moritz
John
etc.
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
_________________________________________________________________
¡Entra en el Club oficial de Messenger y te enterarás de todas las novedades!
http://www.vivelive.com/ilovemessenger
        List of databases
   Name | Owner | Encoding > -----------+----------+----------
gis1 | bekas | UTF8
(4 rows)
> GRASS 6.3.0 (opava):~ > db.connect driver=pg database=gis1 > > GRASS 6.3.0 (opava):~ > db.test test=test1
> etc.
'psql -h localhost gis1' works, I enter psql environment with this.
I' ve tried to change some items but without success. (I am using Ubuntu Hardy Heron.)
I am sending the important part of the postgresql.conf file:
Thank you very much for your help.
# FILE LOCATIONS
# The default values of these variables are driven from the -D command-line
# option or PGDATA environment variable, represented here as ConfigDir.
data_directory = '/var/lib/postgresql/8.3/main' # use data in another directory
          # (change requires restart)
hba_file = '/etc/postgresql/8.3/main/pg_hba.conf' # host-based authentication file
ident_file = '/etc/postgresql/8.3/main/pg_ident.conf' # ident configuration file
# If external_pid_file is not explicitly set, no extra PID file is written.
external_pid_file = '/var/run/postgresql/8.3-main.pid' # write an extra PID file
# CONNECTIONS AND AUTHENTICATION
# - Connection Settings -
#listen_addresses = 'localhost' # what IP address(es) to listen on;
          # comma-separated list of addresses;
          # defaults to 'localhost', '*' = all
port = 5433 # (change requires restart)
max_connections = 100 # (change requires restart)
# Note: Increasing max_connections costs ~400 bytes of shared memory per
# connection slot, plus lock space (see max_locks_per_transaction). You might
# also need to raise shared_buffers to support more connections.
#superuser_reserved_connections = 3 # (change requires restart)
unix_socket_directory = '/var/run/postgresql' # (change requires restart)
#unix_socket_group = '' # (change requires restart)
#unix_socket_permissions = 0777 # begin with 0 to use octal notation
#bonjour_name = '' # defaults to the computer name
# - Security and Authentication -
#authentication_timeout = 1min # 1s-600s
ssl = true # (change requires restart)
#ssl_ciphers = 'ALL:!ADH:!LOW:!EXP:!MD5:@STRENGTH' # allowed SSL ciphers
#password_encryption = on
#db_user_namespace = off
# Kerberos and GSSAPI
#krb_server_keyfile = '' # (change requires restart)
#krb_srvname = 'postgres' # (change requires restart, Kerberos only)
#krb_server_hostname = '' # empty string matches any keytab entry
#krb_caseins_users = off # (change requires restart)
#krb_realm = '' # (change requires restart)
# - TCP Keepalives -
# see "man 7 tcp" for details
#tcp_keepalives_idle = 0 # TCP_KEEPIDLE, in seconds;
          # 0 selects the system default
#tcp_keepalives_interval = 0 # TCP_KEEPINTVL, in seconds;
#tcp_keepalives_count = 0 # TCP_KEEPCNT;
Perhaps : check and adjust the port in the .conf file.
Value in your .conf is port = 5433,
but message says no connection on Is the server running locally and accepting connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432 ?
or try uncommenting the line
#listen_addresses = ‘localhost’
in the .conf file
Le samedi 04 octobre 2008 à 21:35 +0200, Stanislav Bek a écrit :
>> Hi,
>>         List of databases
>>  gis1      | bekas    | UTF8
>> (4 rows)
>> > etc.
# FILE LOCATIONS
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
Benoit ANDRE
Géologue - Hydrologue
Bureau Conseil en Géologie
Rue de Leuze, 433
B-5300 VEZIN
BELGIQUE
Tél.: +32 81 58 26 11
Fax.: +32 81 58 26 12
Contacter…
        List of databases
gis1 | bekas | UTF8
(4 rows)
Try:
to connect using TCP.
Also, "netstat -ax" will list active Unix-domain sockets. If
postmaster is accepting local (Unix-domain) connections, its socket
will be listed there. E.g. I have:
unix 2 [ ACC ] STREAM LISTENING 3442 /tmp/.s.PGSQL.5432
If it's listening on a Unix-domain socket, check that you have the
necessary permissions on both the socket and its parent directories.
        List of databases
gis1 | bekas | UTF8
(4 rows)
Try:
With this, it does not work yet.
So I've done:
GRASS 6.3.0 (opava):~/skripty > netstat -ax| grep post
unix 2 [ ACC ] STREAM LISTENING 13460 /var/run/postgresql/.s.PGSQL.5433
sudo chmod 777 /var/run/postgresql/.s.PGSQL.5433
in postgresql.conf there is a line:
After that: db.test test=test1 again without success.
Best regards,
Stanislav
Okay; it may not be listening for TCP connections, but even if it is,
the client is probably using the wrong port; see below.
So I've done:
Note: the error message says .5432 (which is the default), but netstat
says .5433.
Try:
  export PGPORT=5433
in the GRASS shell.
The port can be set in the config file, but also via:
       -p port
        Specifies the TCP/IP port or local Unix domain socket file
        extension on which the postmaster is to listen for connections
        from client applications. Defaults to the value of the PGPORT
        environment variable, or if PGPORT is not set, then defaults to
        the value established during compilation (normally 5432). If you
        specify a port other than the default port, then all client
        applications must specify the same port using either command-
        line options or PGPORT.
If it's set in the config file, clients should pick it up
automatically. But if it's set via -p or $PGPORT, you'll need to set
PGPORT to convey the port to clients.
Try to uncomment the line (cut out the #)
to make it active, but I don’t the problem is there
Or look at the socket : 5432 or 5433. The ‘normal’ socket of psql is 5432.
And also : in the first lines of postgresql.conf, there is a line like this (the adress is in my case) :
listen_addresses = ‘192.168.10.1’
Is this line uncomment (without the #) ? And what are the adresses ?
Benoit.
>>         List of databases
>>  gis1      | bekas    | UTF8
>> (4 rows)
>Try:
>Glynn Clements <[glynn@gclements.plus.com](mailto:glynn@gclements.plus.com)>
So I've done:
Best regards,
Stanislav
Benoit ANDRE
Rue de Leuze, 433
B-5300 VEZIN
BELGIQUE
Contacter…
I have uncommented a restarted the server, but db.test is again not OK.
socket is also 5433... ?
this is part of my .conf file:
Od: benoit.andre@bcgeol.be
Komu: Stanislav Bek &lt;bks@centrum.cz&gt;
&gt; CC: glynn@gclements.plus.com, grass-user@lists.osgeo.org
Datum: 16.10.2008 19:29
Předmět: Re: [GRASS-user] connect to postgreSQL
to make it active, but I don't the problem is there
Or look at the socket : 5432 or 5433. The 'normal' socket of psql is
5432.
listen_addresses = '192.168.10.1'
Benoit.
>> List of databases
>> gis1 | bekas | UTF8
>> (4 rows)
>Try:
So I've done:
Best regards,
Stanislav
Benoit ANDRE
________________________________________________________________________
Rue de Leuze, 433
B-5300 VEZIN
BELGIQUE
Contacter...
What is the result of a
ps ax | grep pos
in an bash shell ?
> Od: [benoit.andre@bcgeol.be](mailto:benoit.andre@bcgeol.be)
> Komu: Stanislav Bek &lt;[bks@centrum.cz](mailto:bks@centrum.cz)&gt;
&gt; CC: [glynn@gclements.plus.com](mailto:glynn@gclements.plus.com), [grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
>5432.
>Benoit.
>> >>         List of databases
>> >>  gis1      | bekas    | UTF8
>> >> (4 rows)
>> >Try:
>> So I've done:
>> Best regards,
>> Stanislav
>Benoit ANDRE
>Rue de Leuze, 433
>B-5300 VEZIN
>BELGIQUE
>Contacter...
Benoit ANDRE
Rue de Leuze, 433
B-5300 VEZIN
BELGIQUE
Contacter…
