[GRASS-user] Create a point along a line in a specified distance from another point
is there an easy straight forward command to create a new point on a line that is in a specified distance (e.g. 1000 m) from another point (on the same line)?
Just an example (of course from river science): I have a sampling site on a river line. I’d like to use these new point(s) to break the original river lines in order to extract a line segment that is exactly e.g. 2000 m long (1000 up- and downstream the sampling site).
I had a look in v.to.points but this tool only creates points in equidistant steps irrespective of any other points (e.g. sampling points). Another option would be using v.buffer around the sampling points and then v.overlay. However, this approach would “cut” the river lines in euclidean distance from the sampling site rather then in line/river distance.
Any suggestions?
/J
On 17/10/17 15:42, Johannes Radinger wrote:
Just an example (of course from river science): I have a sampling site on a river line. I'd like to use these new point(s) to break the original river lines in order to extract a line segment that is exactly e.g. 2000 m long (1000 up- and downstream the sampling site).
I had a look in v.to.points but this tool only creates points in equidistant steps irrespective of any other points (e.g. sampling points). Another option would be using v.buffer around the sampling points and then v.overlay. However, this approach would "cut" the river lines in euclidean distance from the sampling site rather then in line/river distance.
Any suggestions?
v.net.iso ?
Moritz
Any suggestions?
v.net.iso ?
Or perhaps better: v.lrs.segment ?
Moritz
(on the same line)?
Any suggestions?
v.net.iso ?
Moritz
grass-user mailing list
grass-user@.osgeo
See
https://grass.osgeo.org/grass72/manuals/addons/v.fixed.segmentpoints.html
to get equidistant points along a line. It's a wrapper about v.segment.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
