[GRASS-user] create location from CLI
Dear All,
    I'm trying to understand the simplest way in GRASS7 to create a location from the command line without using a georeferenced file. So far, it appears to be
% grass70 -c newLocation
at the OS prompt, followed by
GRASS GIS 7.0.4 > g.proc -c wkt=some WKT text file
inside of the new GRASS location (which temporarily has a generic XY non-projection). Two things:
1) I can't seem to coerce grass70 or g.proj to do this in a single step from the OS command line (probably missing environment variables when trying to go straight to g.proj from OS CLI).
2) I would prefer to use g.proj -c proj4=some PROJ4 string or file but I can't seem to get g.proj to parse any proj4 strings either from stdin or a file, even substituting the output from a g.proj -j command from a working location.
GRASS 7.0.4
grass70 --config
x86_64-pc-linux-gnu
./configure --prefix=/opt/grass --with-freetype-includes=/usr/include/freetype2 --with-wxwidgets --with-readline --with-pthread --with-netcdf --with-nls --with-geos --with-postgres
uname -a
Linux luthertucker 4.6.4-1-ARCH #1 SMP PREEMPT Mon Jul 11 19:12:32 CEST 2016 x86_64 GNU/Linux
Thanks, Dave
David W. Roberts office 406-994-4548
Professor and Head FAX 406-994-3190
Department of Ecology email droberts@montana.edu
Montana State University
Bozeman, MT 59717-3460
You say "without using a georeferenced file" but then use the WKTfile. Why not use that at the CLI?
grass70 -e -c WKTfile newLocation
grass70 ./newLocation/PERMANENT
I do it in two lines and use -e on the first so that if I run this again, and the location exists, it will still launch GRASS. If you just do the first line w/o -e, GRASS won't start if the location exists.
A MWE would help debugging.
  -k.
Hi
I’m trying to understand the simplest way in GRASS7 to create a location from the command line without using a georeferenced file. So far, it appears to be
Did you try parsing the EPSG code of the location you want to create?
For example:
grass71 -c epsg:3035 /home/user/grassdata/mynewlocation
The above command will create a new location in epsg 3035 projection.
You can find some details here:
https://grasswiki.osgeo.org/wiki/GRASS_Location_Wizard#GRASS_GIS_7:_Creating_locations_from_command_line
Best
Sajid
On Tue, Sep 6, 2016 at 4:13 PM, Sajid Pareeth <spareeth@gmail.com> wrote:
Hi
For example:
In GRASS GIS 7.2 you can even create and import in a single line,
using the new --exec magic:
mneteler@wernstrom ~ $ grass72 -c epsg:3035 ~/grassdata/newloc3035
--exec g.region -p
Cleaning up temporary files...
Creating new GRASS GIS location/mapset...
Executing <g.region -p> ...
projection: 99 (ETRS89 / LAEA Europe)
zone: 0
datum: etrs89
ellipsoid: grs80
north: 1
south: 0
west: 0
east: 1
nsres: 1
ewres: 1
rows: 1
cols: 1
cells: 1
Execution of <g.region -p> finished.
Pretty powerful (instead of direct GRASS commands you can also specify
a script etc.).
See
https://grass.osgeo.org/grass72/manuals/grass7.html#examples
PS: Yes, we will release 7.2 soon but yet fixing some last minutes issues...
Hi Ken, Hi Sajid,
    Thanks for the pointers. I think my problem is that grass70 and g.proj parse the files differently. I.e.,
Here is file teste.prj
PROJCS["Lambert_Conformal_Conic",
     GEOGCS["GCS_WGS_1984",
         DATUM["D_WGS_1984",
             SPHEROID["WGS_1984",6378137,298.257223563]],
         PRIMEM["Greenwich",0],
         UNIT["Degree",0.017453292519943295]],
     PROJECTION["Lambert_Conformal_Conic"],
     PARAMETER["standard_parallel_1",40],
     PARAMETER["standard_parallel_2",45],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",-109],
     PARAMETER["false_easting",0],
     PARAMETER["false_northing",0],
     UNIT["Meter",1]]
The following does not work
grass70 -e -c teste.prj teste
ERROR: ERROR 4: `teste.prj' not recognised as a supported
file format.
ERROR: Could not read georeferenced file teste.prj using either OGR nor
        GDAL
However, this does work
grass70 -c teste
g.proj -c wkt=teste.prj
    I'm having even worse luck with PROJ4 syntax of files.
Sajid, I have no problem getting EPSG specs to work, but that's a lttle too indirect for the audience I'm trying to reach.
Thanks, Dave
  -k.
ERROR: Could not read georeferenced file teste.prj using either OGR >nor
> GDAL
AFAIK the prj file holds the projection information, but the georeferenced
file would be e.g. the related *.shp file.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/create-location-from-CLI-tp5284306p5284388.html
On Sep 6, 2016 9:25 PM, “Dave Roberts” <droberts@montana.edu> wrote:
Hi Ken, Hi Sajid,
PROJCS[“Lambert_Conformal_Conic”,
GEOGCS[“GCS_WGS_1984”,
DATUM[“D_WGS_1984”,
SPHEROID[“WGS_1984”,6378137,298.257223563]],
PRIMEM[“Greenwich”,0],
UNIT[“Degree”,0.017453292519943295]],
PROJECTION[“Lambert_Conformal_Conic”],
PARAMETER[“standard_parallel_1”,40],
PARAMETER[“standard_parallel_2”,45],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,-109],
PARAMETER[“false_easting”,0],
PARAMETER[“false_northing”,0],
UNIT[“Meter”,1]]
Creating new GRASS GIS location/mapset…
ERROR: ERROR 4: `teste.prj’ not recognised as a supported
file format.
GDAL
Yes because it is not a raster or vector file.
grass70 -c teste
This one is right.
I’m having even worse luck with PROJ4 syntax of files.
AFAIK that’s only supported in g.proj.
Thanks for clarification Markus, and thanks Helmut for similar input. So, the last problem is that
g.proj -c proj4=-
followed by input to stdin works, but I cannot seem to construct a file with proj4 parameters that g.proj will accept, even though identical information entered at stdin works. So, I'm still struggling for the syntax of aproj4 file I guess.
Thanks all, Dave
On 09/06/16 14:37, Markus Neteler wrote:
On Sep 6, 2016 9:25 PM, "Dave Roberts" <droberts@montana.edu
<mailto:droberts@montana.edu>> wrote:
Hi Ken, Hi Sajid,
        DATUM["D_WGS_1984",
    UNIT["Meter",1]]
file format.
       GDAL
grass70 -c teste
This one is right.
AFAIK that's only supported in g.proj.
g.proj -c proj4=-
The proj4 parameter in g.proj takes a PROJ string description, not a file containing one.
So,
g.proj -c proj4="+proj=longlat +datum=WGS84"
should work, as far as I can think.
Paul
Paul,
So,
   Indeed it does, and that seems to be the end of the line. So it's possible to create an arbitrary locations with nothing but projection information (no data yet), but it takes two lines of code. That works for me. When I migrate to 7.2 apparently I can do it in one.
Thanks all, Dave
On Wed, Sep 7, 2016 at 12:28 AM, Paul Kelly
containing one.
So,
BTW:
Are there reasons to not support proj4= also in the startup script "grass72"?
On Wed, Sep 7, 2016 at 4:01 AM, Markus Neteler <neteler@osgeo.org> wrote:
BTW:
"grass72"?
I don't think so. If somebody wants to look at it, this is the file to
change (long, but you can ignore most of it for this project):
https://trac.osgeo.org/grass/browser/grass/trunk/lib/init/grass.py
Vaclav
