About a year ago I used v.in.ascii to create a point map and save the
attribute data in a postgres table. Now I already have those data in a table
and want to create a points map using the geographic coordinates (x=col 2,
y=col 3), but associating the holeid and other attributes with each point.
I've run db.connect and db.login within the project location/mapset and
now need to create a vector point ('sites') map from these data. The table
schema is,
CREATE TABLE boreholes (
holeid TEXT PRIMARY KEY,
easting NUMERIC(13,6) NOT NULL,
northing NUMERIC(13,6) NOT NULL,
surf_elev REAL,
holedepth INTEGER,
purpose VARCHAR(16),
lithology VARCHAR(16),
hole_diam REAL,
well_diam REAL,
flow_gpm REAL,
h2o_elev REAL,
comment TEXT
Can I use v.in.ogr to create a GRASS vector map from these data?
If not, I can create an ASCII text file of the data and use v.in.ascii to
create the map. If this is the way to proceed, I suppose that I need to
empty that database table so the column values will be loaded as v.in.ascii
runs.
Or, have I completely missed how to do this?
TIA,
Rich
v.in.ascii runs.
Well, creating an ascii text file with 4 columns and trying v.in.ascii I
see the error that the database table cannot be created.
Rich
table
schema is,
surf_elev REAL,
holedepth INTEGER,
hole_diam REAL,
well_diam REAL,
flow_gpm REAL,
h2o_elev REAL,
comment TEXT
Try v.in.db.
Moritz
On Sun, 18 Mar 2012, Moritz Lennert wrote:
Try v.in.db.
Moritz,
For reasons I cannot explain I completely missed this module when going
through the list. Thank you for pointing out the obvious.
Rich
Try v.in.db.
Moritz,
Knowing that there are "over 435 built-in analysis modules" in GRASS (6.4.2 release notes), it is quite normal to not always easily find the one you want at first try
Moritz
