[GRASS-user] csh syntax
I found the bash command for adding up rasters as
$str="r.mapcalc map=ts.1"
$for i in `seq ts.2 ts.120`; do
str=$str+" + map$i", done
I need this exact command, but in csh I have been playing with the syntax and cannot seem to get it to work. I know I will switch out "for i in" for like foreach, but the "str" command is not interchangable, and neither is the "seq" command.
Any suggestions are greatly appreciated.
Aaron
Try this:
set i=1
set str="r.mapcalc map=ts.1"
while($i <= 120)
  set str="$str + map.$i"
  @ i++
end
echo $str
--Wolf
Aaron
grassuser mailing list
grassuser@grass.itc.it
<:3 )---- Wolf Bergenheim ----( 8:>
