Hi Markus and Moritz,
Thanks for your suggestions; I tried another loop (the one from v.in.db) and gave the result that I needed. Below are my “experiments”:
The first db_fetch loop (exits after one interaction): I have to “cheat” to be able to get all the records from the database:
while(1){
if(db_fetch (&cursor, DB_NEXT, &more) != DB_OK)
return(-1);
nodeprop=db_get_value_as_double(dbvalue,ctype);
printf(“node prop= %.2f\n”,nodeprop);
count++;
if(count<12699) /* use max(cat) value for this one, just testing*/
more=0;
if ( more) break;
Now, using the loop as used in v.in.db I get what I need, without "cheating’:
while ( db_fetch (&cursor, DB_NEXT, &more ) == DB_OK && more ) {
There are two differences: on the first loop more==1 immediately, and thus exits the loop; while on the second one the loop is exptecting more==1. Another difference is the != or == DB_OK part.
What I can gather from this, is that the first loop is more appropriate to queries done on a category basis, but not for fetching an entire table.
Jaime
Moritz Lennert moritz.lennert@ulb.ac.be escribió:
On 20/03/08 00:19, Jaime Carrera wrote:
Hi list,
My apologies if this question fits better in the developers list.
I’m trying to understand how db_fetch works and why am getting a strange
error.
After a query is executed and db_open_select_cursor is used, db_fetch is
used to fetch the data of the resultant query. AFAIK, db_fetch(&cursor,
DB_NEXT, &more) fetches the data on a row by row basis; is this correct?Yes.
My problem is that everything works fine on my program except the
db_fetch loop, as the loop breaks after the first iteration (although my
table has 3000 rows).
Can someone help me to figure out why the loop breaks?Is your cursor correct ? Are you checking for DB_OK ? What is the status
of more ? You defininetely have to check for the former and possibly for
the latter (as in some of the examples Markus sent, i.e. v.in.db/main.c.)In general, it would be helpful to send your code to understand what is
happening.Moritz
¡Capacidad ilimitada de almacenamiento en tu correo!
No te preocupes más por el espacio de tu cuenta con Correo Yahoo!:
http://correo.espanol.yahoo.com/
