[GRASS-user] db.select limitation + psql workaround
db.select balks when the SELECT queries are sufficiently complex (experienced in GRASS6.3).
Example:
echo
"SELECT county_id,county_name_ascii, max(area) INTO ovl_max FROM (SELECT county_id::integer,county_name_ascii,met_id,area FROM ovl_110 GROUP BY county_id,county_name_ascii,area,met_id ORDER BY county_name_ascii) FOO GROUP BY FOO.county_name_ascii,FOO.county_id;"
| db.select
results in:
DBMI-Postgres driver error:
Cannot select:
For Linux/PostgresQL this can be circumvented by using a single line call to psql with the identical SQL command:
psql -c
-dmeteo_null
Best,
Peter
Dr. Peter Löwe
<peter.loewe@gmx.de>
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger
On 16/01/09 16:06, peter.loewe@gmx.de wrote:
Example:
echo "SELECT county_id,county_name_ascii, max(area) INTO ovl_max FROM (SELECT county_id::integer,county_name_ascii,met_id,area FROM ovl_110 GROUP BY county_id,county_name_ascii,area,met_id ORDER BY county_name_ascii) FOO GROUP BY FOO.county_name_ascii,FOO.county_id;" | db.select
results in:
Cannot select:
Could this be because of the SELECT ... INTO which in my logic is a special case of the SELECT statement which would need to be executed via db.execute as db.select only handles "pure" selections, i.e. no modifications or creations ?
Moritz
> Example:
> echo
> | db.select
> results in:
> Cannot select:
Moritz
I do agree. However, since the statement begins with the "SELECT"-string, db.execute refuses to execute it.
Peter
Dr. Peter Löwe
> > Example:
> > echo
> > | db.select
> > results in:
> > Cannot select:
Technically, SELECT INTO is an entirely different command to SELECT,
not a special case of it.
[Similarly, there is no CREATE command, only CREATE TABLE, CREATE
DATABASE, and so on.]
FWIW, the PostgreSQL documentation says that CREATE TABLE AS (which is
a different command to CREATE TABLE) is the recommended method.
This is a bug in db.execute, and the only simple fix is to remove the
check altogether.
Distinguishing SELECT from SELECT INTO is hard enough if you know the
exact language syntax, but db.execute has to work with all DBMI
drivers. The only realistic way to perform such a check would be to
implement it in the individual drivers.
On Sat, Jan 17, 2009 at 11:51 AM, Glynn Clements
check altogether.
As simple as this?
Index: db/base/execute.c
--- db/base/execute.c (revision 35372)
+++ db/base/execute.c (working copy)
@@ -135,7 +135,7 @@
static int get_stmt(FILE * fd, dbString * stmt)
- char buf[4000], buf2[4000], buf3[7];
+ char buf[4000], buf2[4000];
     int len, row = 0;
     db_init_string(stmt);
@@ -145,11 +145,6 @@
        G_chop(buf2);
        len = strlen(buf2);
- G_strncpy(buf3, buf2, 6);
- if (G_strcasecmp(buf3, "select") == 0)
- G_fatal_error(_("Use db.select for SELECT SQL statements"));
- len = strlen(buf2);
        if (buf2[len - 1] == ';') { /* end of statement */
            buf2[len - 1] = 0; /* truncate ';' */
            db_append_string(stmt, buf2); /* append truncated */
If so, I suggest to do it also in GRASS 6.4.x.
> check altogether.
As simple as this?
Yes.
On Sat, Jan 17, 2009 at 8:27 PM, Glynn Clements
> check altogether.
As simple as this?
Yes.
Done in 7.trunk, devel6 and 6.4.0svn.
Thanks for your work, Markus !
Peter
-------- Original-Nachricht --------
Datum: Sun, 18 Jan 2009 07:23:56 +0100
Von: Markus Neteler <neteler@osgeo.org>
An: Glynn Clements <glynn@gclements.plus.com>
CC: GRASS user list <grass-user@lists.osgeo.org>, "Peter Löwe" <peter.loewe@gmx.de>
Betreff: Re: [GRASS-user] db.select limitation + psql workaround
>> > check altogether.
>> As simple as this?
> Yes.
Dr. Peter Löwe
Sensationsangebot verlängert: GMX FreeDSL - Telefonanschluss + DSL
für nur 16,37 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K1308T4569a
