[GRASS-user] Defining Minimum Mapping Units
Greetings all
I’ve been reading a Remote Sensing classic “Remote Sensing and Image intepretation” by Lillesand and Kiefer. :slight_smile:
By Those guys Minimum Mapping Units are the smallest size areal entity to be mapped as a discrete area.
They also state that: The size of a minimum area that can be mapped as any particular land use/land cover class depends on the scale and resolution of the satellite images."
Ok, now my “situation” :). I need to produce a few land cover maps, after classification, with an aggregation of a defined minimum mapping unit(MMU) for a scale of 1:50000. As far as I can see, I would say that MMU would be minumum size of a polygon that can be mapped. For istance what Would I have to do to aggregate a classification map with a minimum area of 20 km^2?
Thanks
Best regards
On Wed, Jan 20, 2010 at 7:03 PM, Luis Lisboa <luislisboa1975@gmail.com> wrote:
Greetings all
I've been reading a Remote Sensing classic "Remote Sensing and Image
intepretation" by Lillesand and Kiefer. :slight_smile:
Ok, now my "situation" :). I need to produce a few land cover maps, after
Quick answer without thinking too much:
- r.reclass.area: Reclasses a raster map greater or less than user
specified area size (in hectares).
or
- v.clean, tool rmarea: remove small areas, the longest boundary with
adjacent area is removed
