[GRASS-user] Description of WILDFIRE
Hi
I am looking for a description of the layers needed and what they represent and how the module r.ros, r.spread are calculating the spread of fires. Especially a definition of the fuel model would be usefull.
Is there something like that available online?
Thanks
Rainer
These modules are performing rate of spread calculationons for each cell based on Rothermel equation for rate of spred (r.ros) and then performing 2D eliptical spread simulation.
Fuel model used in this module is 13 category model defined by Anderson and described in
http://www.firemodels.org/downloads/behaveplus/publications/Anderson_INT-122_1982.pdf
I am using the module in my work, but I am using grass 5.7 becouse when I use higher version of grass the r.spread freezes, and I still didn't get the answer why.
If you notice that the new version of grass is performing r.spread without failure please let me know :slight_smile:
best regards
Ljiljana Bodrozic
Department for modeling and inteligent systems
Faculty of Electrical Engineering, Mechanical Engineering and Naval Architecture
University of Split
Rainer M Krug wrote:
Hi
Thanks
Rainer
grass-user mailing list
grass-user@lists.osgeo.org
Hi Ljiljana
thanks for your response
That is exactlyu what I was looking for - thanks.
Oops - I am using 6.2.3 at the moment - I will definitely keep you posted.
Sure
regards,
Rainer
best regards
Ljiljana Bodrozic
University of Split
Hi
Thanks
Rainer
