On Mon, Jun 23, 2008 at 9:08 PM, Markus Neteler <neteler@osgeo.org> wrote:
Rainer,
I suggest to try the snap parameters of v.in.ogr first. Maybe the SHAPE
file is full of gaps and slivers (commonly found, even in governmental
data).
*Small* snapping values might cure it. Be careful to not snap, say,
Africa to a triangle
Thanks Markus,
but the information is there. If I display the layer and select
layer=2, I see the overlapping areas, and if I click i=on them to get
information (v.what -a map=fires@simulation ...), I get the following
info:
East: 255207.46888
North: 6235456.43154
Map: fireHistory
Mapset: simulation
Type: Centroid
Line: 3202
Layer: 1
Category: 4
Driver: dbf
Database: /home/rkrug/Documents/Projects/AlienSpread/R/../grass/simulation/dbf/
Table: fireHistory
Key column: cat
cat : 4
YEAR : 2005
Layer: 1
Category: 178
Driver: dbf
Table: fireHistory
Key column: cat
cat : 178
YEAR : 1993
Layer: 1
Category: 208
Driver: dbf
Table: fireHistory
Key column: cat
cat : 208
YEAR : 1995
Layer: 2
Category: 3 <<---
and the one value marked by <<-- is the one which IO want to extract
into a raster or vector map.
Even if I do
v.extract input=fireHistory@simulation output=fires
type=point,line,boundary,area layer=2
it gives me the areas, but no associated attribute table.
On Mon, Jun 23, 2008 at 12:13 PM, Rainer M Krug <r.m.krug@gmail.com> wrote:
Hi
I am importing a vector layer from a shape file as follow, and get the
warning below:
> v.in.ogr dsn=/home/rkrug/Documents/Projects/AlienSpread/data/input/
> layer=fireHistory output=fireHistory --overwrite
WARNING: 703 areas represent more (overlapping) features, because polygons
overlap in input layer(s). Such areas are linked to more than 1
row in attribute table. The number of features for those areas is
stored as category in layer 2
I am aware of that, and I want to create a raster layer with the
number of features overlapping in each location. As I ultimately need
a raster layer, I thought to use the following, but I get the error
message below:
> v.to.rast input=fireHistory layer=2 output=mf use=attr column=category
> --overwrite
ERROR: Unable to get layer info for vector map
Why is that?
Is there another way of getting the number of overlapping features per
cell?
Thanks
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Plant Conservation Unit
Department of Botany
University of Cape Town
Rondebosch 7701
South Africa
grass-user mailing list
grass-user@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
Rondebosch 7701
South Africa
