Hello Ivan,
Thanks for coming back to this
I see what you did with creating the days time series. In that way you acknowledge irregular gaps, right? Otherwise, as t.rast.series method=slope,offset uses r.series in the background, it will use index as independent variable and therefore maps are considered equally separated in time.
However, why do you multiply by days strds? From my understanding, detrending by subtracting the results of a model obbeys this rule: value(t) = observed(t) - predicted(t). Then, this mystrds-(regression_offset+regression_slopedays) should be mystrds-(regression_offset+regression_slopemystrds).
Best,
Vero
El jue, 28 dic 2023 a las 8:14, Ivan Marchesini (<ivan.marchesini@gmail.com>) escribió:
Dear Veronica
I think I found a simple solution using temporal raster modules. Here is an example:
#evaluating info of the strds
eval [t.info](http://t.info) mystrds -g
#getting the starting day (of the year, 0-365) of my strds
startday=$(date -d “$start_time” “+%j”)
#Creating a new strds where each pixel has the value of the count of the days starting from the start_day of my strds (the start day in my dataset is in 2016)
t.rast.mapcalc inputs=mystrds expression=“(start_year()-2016)*365-${startday} +start_doy()” output=days basename=days nprocs=xxx --o
#fitting the trend equation
r.regression.series xseries=“t.rast.list in=days columns=name sep=, format=line” yseries=" t.rast.list in=mystrds columns=name sep=, format=line" out=regression_offset,regression_slope,regression_rsq,regression_t meth=offset,slope,rsq,t
#detrending
t.rast.mapcalc input=mystrds,days expression=“mystrds_detrend = mystrds-(regression_offset+regression_slope*days)” output=mystrds_detrend basename=mystrds_detrend nprocs=xxx method=start --o
Best
Ivan
On 23/12/23 14:53, Ivan Marchesini wrote:
Hi Veronica
Thank you. It goes in the direction of my idea evn if my problem is exactly trying to take into account the correct gaps between that data
I have another idea.
if it works I will come back here to explain how I did
thank you again
Ivan
On 22/12/23 13:45, Veronica Andreo wrote:
Hello Ivan,
AFAIU you could use the slope and offset maps from t.rast.series within t.rast.algebra to detrend the values of the maps within the strds, something like “detrended_strds = trend_strds - (trend_strds*map(slope) + map(offset))”. Others suggest, to detrend by subtracting the previous value, i.e. that would imply using the temporal algebra with the temporal index, something like “detrended_strds = trend_strds[1] - trend_strds[0]”.
I haven’t tested any of these, just a couple of ideas
However, I do not know how this might interact with seasonality within data, or irregular gaps.
hth somehow
Vero
El vie, 22 dic 2023 a las 5:10, Ivan Marchesini via grass-user (<grass-user@lists.osgeo.org>) escribió:
Dear colleagues
I would like to the advantage of the t.* modules for detrending a strd.
In the strd I have earth observation data irregularly sampled (2 or 3
times per month), in the period November-February, for 7 years. They are
not equally spaced (i.e gaps have different duration)
A simple t.rast.series analysis (opion=slope,offset) highlights that
probably there is a descending trend when considering the maps ordered
by id.
I would like to fit a proper time depending fitting curve for each pixel
and then subtract the function from the real data.
any hints on how I can do this task exploiting the GRASS GIS modules or
some simple bash/python scripting?
thank you
Ivan
grass-user mailing list
