I just compiled the latest cvs, and get an error when I tried to
display a raster. I set the region in the terminal and choose "zoom to
current region". the error msg is this:
Sorry, <map> is not a valid parameter
ERROR: Required parameter <output> not set:
(Name for output raster map).
Description:
Outputs basic information about a user-specified raster map layer.
Usage:
r.info [-rstghp] output=name [--overwrite]
Flags:
-r Print range only
-s Print raster map resolution (NS-res, EW-res) only
-t Print raster map type only
-g Print raster map region only
-h Print raster history instead of info
-p Print raster map timestamp (day.month.year hour:minute:seconds) only
--o Force overwrite of output files
Parameters:
output Name for output raster map
Description:
Usage:
Flags:
-r Print range only
Parameters:
while executing
"close $rt"
(procedure "GmRaster::display" line 40)
invoked from within
"GmRaster::display $node $mod"
("raster" arm line 2)
invoked from within
"switch $type {
group {
GmGroup::display $node $mod
raster {
labels {
GmLabels::disp..."
(procedure "GmTree::display_node" line 7)
invoked from within
"GmTree::display_node $n $mod"
(procedure "GmGroup::display" line 25)
invoked from within
"GmGroup::display "root" $mod"
(procedure "MapCanvas::runprograms" line 30)
invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
(procedure "MapCanvas::drawmap" line 43)
invoked from within
"MapCanvas::drawmap $mon"
(procedure "MapCanvas::display_server" line 9)
invoked from within
("after" script)
thanks all.
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
