[GRASS-user] Display Of Tiff Raster file Stored on HDD in Grass
I am a new grass user,I have Installed the grass-6.2.3 on my system.but i m not able to Import & display the raster image.(Tiff Image) which is kept on my hard disk 50 mb in size…
could anyone tell the way to see the raster image,i am looking for the standard document for using grass.if anyone having this document,please forward it to me…
Thanks in Advanc
Thanks in Advanc
Thanks & Regards
Kunal Malik
09871147561
Thanks & Regards
Kunal Malik
09871147561
Hi!
(Assuming you have created a LOCATION based on the coordinate system in
which you want to work and in which your data is projected...)
* Using r.in.gdal from the command line or from the GUI under
"File>Impor> Raster map> Multiple formats using GDAL"
* Important is to check the extent and the resolution of your current
working "region". If these settings are not the proper ones the you
don't see anything cause your data are somewhere out of your "screen"
but still inside your LOCATION.
a. With "g.region -p" in the command line or "Config>Region>Display
region settings" you can check the current seetings.
b. Fastest way is to tell r.in.gdal to "extend location extents based
on new dataset" (either with r.in.gdal -e input=... output=... and the
rest or by checking the respective option in the GUI of r.in.gdal)
Hope this helps you a bit...
Image) which is kept on my hard disk 50 mb in size..
document,please forward it to me..
Thanks in Advanc
        image.(Tiff Image)
        this document,please forward it to me..
        Thanks in Advanc
        Thanks & Regards
        Kunal Malik
        09871147561
Thanks & Regards
Kunal Malik
09871147561
grass-user mailing list
grass-user@lists.osgeo.org
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
I forgot to cc to the list before... so once again, and this time more
clear:
* check the projection system information of your tif file with gdalinfo
from the commandline.
(man gdalinfo for help)
* and then... (the message I forgot to cc to the list):
You have to know in which coordinate system your "nf42_geo.tif" data is
projected. If you are sure that your data is projected in the coordinate
system which you assigned in your LOCATION
(with g.region -o you get that info as well)
then just use an extra option to ignore these errors:
-o in the commald line or the respective box in the GUI "Override
projection"
e.g. CLI: > r.in.gdal -e -o in=nf42_geo.tif out=tm
By the way,
it is very helpful and saves time and energy to consult tha help pages
always. There are (almost) always the necessary examples and
explanations.
On Wed, 2008-02-13 at 15:05 +0530, Kunal Malik wrote:
Hi!!
I have done the things required.
but from the command line ,when i am using r.in.gdal -e
-n=nf42_geo.tif out=tm ..
I am getting the message
WARNING: Datum 'unknown' not recognised by GRASS and no parameters
found.
         Datum transformation will not be possible using this
projection
         information.
ERROR: Projection of dataset does not appear to match current
location.
Same messge is coming when I am doing the same through GIS Manager..
Can u help me i this Regards..so that i could open the avalible TIf
On 2/13/08, Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>
wrote:
        Hi!
        system in
        GUI under
        current
        the you
        "screen"
        extents based
        and the
        r.in.gdal)
        > I am a new grass user,I have Installed the grass-6.2.3 on my
        > system.but i m not able to Import & display the raster
        image.(Tiff
        > Image) which is kept on my hard disk 50 mb in size..
        > could anyone tell the way to see the raster image,i am
        looking for the
        > standard document for using grass.if anyone having this
        > document,please forward it to me..
        > Thanks in Advanc
        grass-6.2.3 on my
        raster
        > image.(Tiff Image)
        am looking
        > for the standard document for using grass.if anyone
        having
        > this document,please forward it to me..
        > Thanks in Advanc
        > Thanks & Regards
        > Kunal Malik
        > 09871147561
        > Thanks & Regards
        > Kunal Malik
        > 09871147561
        > grass-user mailing list
        > grass-user@lists.osgeo.org
        > http://lists.osgeo.org/mailman/listinfo/grass-user
        Nikos Alexandris
Thanks & Regards
Kunal Malik
09871147561
Nikos Alexandris
