[GRASS-user] Display point values
Rather than use raster DTM maps I decided to use depth measurement points
themselves.
The data look like this:
lon,lat,depth
7709581.42,697951.64,24
7705545.87,698624.07,16
7709732.27,699488.73,27
7712090.79,699428.24,62
7716863.99,701238.89,32
7701540.85,698790.50,31
7713676.33,699192.82,58
7705283.41,697549.00,31
7705037.10,698489.22,16
The command I'm using is:
d.vect map=lady_channel_sounding_points display=zcoor type=point zcolor=blue size=7
and the resulting map is attached.
Perhaps I should make the computational region smaller to make individual
values visible, but are the display and color values what they should be?
The values are displayed in red, not blue.
TIA,
Rich
(attachments)
(attachments)
themselves.
lon,lat,depth
The command I’m using is:
Here’s what I did. Notice that I added the “-z=3” option to v.in.ascii so that the new points vector is 3D. Then the “zcolor=” option to d.vect works.
Create new Location/Mapset based on the georeference tiff file
grass -c ~/Downloads/columbia_2010_e_dtm_35.tif --text ./columbia/PERMANENT
#Points text file
micha@RMS:tmp$ cat << EOF > depth_points.txt
lon,lat,depth
EOF
Create GRASS vector from CSV file
Note the 'z=3" parameter, to creaate a 3D vector with Z coord
cat depth_points.txt | v.in.ascii input=- output=depth_points separator=comma z=3 skip=1 columns=“x DOUBLE, y DOUBLE, depth DOUBLE” --o
v.info depth_points | grep 3D
| Map is 3D: Yes
g.region -ap vect=depth_points
Display
d.mon wx1
d.vect depth_points zcolor=byr size=10 icon=basic/diamond
Result attached
TIA,
Rich
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
On Thu, 30 Sep 2021, Micha Silver wrote:
Here's what I did. Notice that I added the "-z=3" option to v.in.ascii so
that the new points vector is 3D. Then the "zcolor=" option to d.vect
works.
Micha,
The command I used is:
v.in.ascii -zr in=~/projects/washington/project/data/bathymetry/coe/CL_34_WSHX_20210720_CS.xyz out=wash_transect format=point sep=comma columns='x double precision, y double precision, elev=int' x=1 y=2 z=3
--o
It has the -z option specified. It also has 'z=3' at the end to indicate the
elevation values are the third column in the file.
If I replace -zn with -z=3 GRASS tells me:
ERROR: v.in.ascii: Sorry, <=> is not a valid flag
ERROR: v.in.ascii: Sorry, <3> is not a valid flag
And GRASS still tells me:
ERROR: Unable to open input file
        </home/rshepard/projects/washington/project/data/bathymetry/coe/CL_34_WSHX_20210720_CS.xyz>:
        No such file or directory
It's quite frustrating as it had no problem finding CL_33_LDYX_20210712_CS.xyz
in the same directory just before I entered the command for importing CL_34_WSHX_20210720_CS.xyz.
Rich
