Dear community,
in v.buffer there is distance and minordistance (see manual).
Perhaps this can be better explained.
Is there an on-the-fly identification of the longest and shortest axis
of the vector shape to be buffered? Does this apply only to certain
types?
Thank you, Nikos
On 17/05/17 16:20, Nikos Alexandris wrote:
Dear community,
types?
This only makes sens for buffers around points, AFAIU: if you only supply 'distance' you get circular buffers, if you also supply 'minordistance' you get ellipsoidal buffers.
Moritz
On Wed, May 17, 2017 at 4:37 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Dear community,
types?
This only makes sens for buffers around points, AFAIU: if you only supply ‘distance’ you get circular buffers, if you also supply ‘minordistance’ you get ellipsoidal buffers.
The minordistance option is used only with the GRASS internal buffering method which never worked. The default buffering method of v.buffer uses GEOS which does not support ellipsoidal buffers defined by major and minor distances.
Markus M
