[GRASS-user] Elevation differences between endpoints of least cost paths
I'm stating with a DEM (named FD).
First I find streams:
  r.watershed elevation=FD stream=stream
  r.thin input=stream output=stream.thin
Then, for each point on the DEM, I need
The distance to the nearest point in a stream
The elevation difference to the stream point
I can get the distance by gollowing the example "Computing a distance map"
in Neteler & Mitasova's GRASS book:
  r.mapcalc area.one=1
  r.cost -k input=area.one output=dtv start_rast=stream.thin
So far so good, and the results make sense
But I would very much appreciate suggestions for the elevation difference.
I have been looking at various r.* routines, such as r.drain, but haven't
yet found a solution. I have very little experience with raster analysis.
(and in fact, I'm using the R package spgrass6 to manage the above steps)
Thanks
-Don
Don MacQueen
Lawrence Livermore National Laboratory
7000 East Ave., L-627
Livermore, CA 94550
925-423-1062
Hi Don
I think you can solve this using grass 7 (you can download it from http://grass.osgeo.org/download/software/). This version includes a new option for r.cost that copies the value of the nearest cell. You can solve the problem using
r.mapcalc "streamH=if(isnull(stream.thin),null(),FD)"
r.cost -k input=area.one output=dtv start_rast=streamH nearest=nearestH
nearestH will contains the elevation of the nearest stream
Best regards
Juan Carlos Torres | http://lsi.ugr.es/~jctorres
Laboratorio de Realidad Virtual | Tlf.: (+34) 645 885 167
Dpto. Lenguajes y Sistemas Informaticos | (+34) 958 249 307
ETS. Ing. Informatica | interno ugr 71 260
Univ. de Granada | FAX: (+34) 958 243 179
Thanks
-Don
Thank you!
-Don
Hi Don
r.mapcalc “streamH=if(isnull(stream.thin),null(),FD)”
Best regards
Thanks
-Don
