/*hello
I couldn't do with v.clean what I wanted to do.
I want to eliminate all lines whose their langth are under 20 m.
what is the solution ?
regards
Ahmet Temiz
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
temiz wrote:
/*hello
not tested:
v.to.db map=Original option=length type=line col=linelength units=me
v.extract input=Original output=Original20 where="linelength>20"
Moritz
On Thu, Nov 02, 2006 at 10:24:49AM -0500, temiz wrote:
/*hello
regards
You could add a new column with v.db.addcol and then
upload the vector line lengths to this column with
v.to.db and option=length.
Then use v.extract with a simple SQL rule to extract
all but lengths < 20m.
Moritz Lennert wrote:
temiz wrote:
/*hello
not tested:
Moritz
thank you Moritz and Markus
I solved this problem ( grass is really capable).
When I looked at v.to.db, I thought whether I could calculate
the "length of a polygon" as well.
Do you have idea ?
thanks again
Ahmet Temiz
temiz wrote:
/*hello
not tested:
Moritz
Depends on the polygon. If it defined as a boundary, then try setting
type=boundary and option=length
If it is an area then type=area and option=perimeter
Moritz
H_B
November 2, 2006, 11:34pm
6
note "v.clean tool=rmarea thresh=.. " is prefered for removing small
areas, as polygon boundary length is a fractal problem.
Hamish
