Hi Ludvico,
You also want to check how the binary was written in FORTRAN. depending on the compiler and/or the access type fortran can write extra bytes before and after every record (they are called record marker). In that particular case the file would be bigger than the information it is supposed to contain. It is explained here: http://paulbourke.net/dataformats/reading/
I copied the content of the site below in case the link doesn’t make it.
Problem
Ever wanted to read binary files written by a FORTRAN program with a C/C++ program? Not such an unusual or unreasonable request but FORTRAN does some strange things … consider the following FORTRAN code, where “a” is a 3D array of 4 byte floating point values.
open(60,file=filename,status='unknown',form='unformatted')
write(60) nx,ny,nz
do k = 1,nz
do j = 1,ny
write(60) (a(i,j,k),i=1,nx)
enddo
enddo
close(60)
What you will end up with is not a file that is (4 * nx) * ny * nz + 12 bytes long as it would be for the equivalent in most (if not all) other languages! Instead it will be nz * ny * (4 * nx + 8) + 20 bytes long. Why?
Reason
Each time the FORTRAN write is issued a “record” is written, the record consists of a 4 byte header, then the data, then a trailer that matches the header. The 4 byte header and trailer consist of the number of bytes that will be written in the data section. So the following
write(60) nx,ny,nz
gets written on the disk as follows where nx,ny,nz are each 4 bytes, the other numbers below are 2 byte integers written in decimal
0 12 nx ny nz 0 12
The total length written is 20 bytes. Similarly, the line
gets written as follows assuming nx is 1024 and “a” is real*4
10 0 a(1,j,k) a(2,j,k) .... a(1024,j,k) 10 0
The total length is 4104 bytes. Fortunately, once this is understood, it is a trivial to read the correct things in C/C++.
A consequence that is a bit shocking for many programmers is that the file created with the above code gives a file that is about 1/3 the size than one created with this code.
write(60) nx,ny,nz
do k = 1,nz
do j = 1,ny
do i = 1,nx
write(60) a(i,j,k)
enddo
enddo
enddo
close(60)
In this case each element of a is written in one record and consumes 12 bytes for a total file size of nx * ny * nz * 12 + 20.
Hope it helps
On Wed, May 8, 2013 at 5:27 AM, Hamish <hamish_b@yahoo.com> wrote:
Ludovico wrote:
Thank you for your answers. A few info on my system:
I’m running on a computational node under linux with 64GB or
RAM the machine architecture is a x86_64 and the kernel is
also 64bit (running getconf LONG_BIT output is 64)
The version of GRASS I am running is 6.4.1
You’ll have to upgrade to a newer version. The fix for r.in.bin
was added just a few days after the release of 6.4.1, which was
two years ago.
I’d suggest 6.4.3rc3, get in early and help us test the upcoming
release.
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
