[GRASS-user] error: command 'gcc' failed with exit status 1
Hi everyone!
As suggested in this link: http://osgeo-org.1803224.n2.nabble.com/wxpython-gui-and-v-digit-td3019439.html and https://svn.osgeo.org/grass/grass/trunk/gui/wxpython/README - 6. VECTOR DIGITIZER I have been trying to compile/install vdigit component. I could install GRASS with C++ (–with-cxx), Python (–with-python) and wxWidgets (–with-wxwidgets) support. But in the next step when I change to the directory “cd gui/wxpython/vdigit” and run make I get the following error:
cats.cpp:456: error: ‘Vect_rewrite_line’ was not declared in this scope
cats.cpp:461: error: ‘G_debug’ was not declared in this scope
cats.cpp:467: error: ‘Vect_destroy_line_struct’ was not declared in this scope
cats.cpp:468: error: ‘Vect_destroy_cats_struct’ was not declared in this scope
make: *** [OBJ.x86_64-unknown-linux-gnu/_grass6_wxvdigit.so] Error 1
I use Ubuntu 10.10 with GRASS 6.4.1svn. I tried installing python-dev, python2.6-dev packages as suggested in many forums but the error continued to appear.
Thanks and regards,
Chethan S.
Chethan S.
PG Student | Remote Sensing and Geographic Information Systems
National Institute of Technology Karnataka | Surathkal
Karnataka | India - 575 025
2011/3/22 Chethan S <chethanuniversal@gmail.com>:
install GRASS with C++ (--with-cxx), Python (--with-python) and wxWidgets
(--with-wxwidgets) support. But in the next step when I change to the
directory "cd gui/wxpython/vdigit" and run make I get the following error:
please don't waste your time with C++ wxGUI vector digitizer. This
component has been replaced by Pythonized version in GRASS 6.5+. It
will be included in 6.4.2.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
