[GRASS-user] Error in d.vect.chart
I am using d.vect.chart to plot some bars to indicate a level. But, the
lines on the right and left sides of the bars extends all the way down
to the bottom of the map... (www.radioecology.info/images/Fisk1992.png)
As a quick work around, is it anyhow possible to avoid having an
outline, or to have a transparent outline?
Morten Sickel
Norwegian Radiation Protection Authority
Just a couple of follow-ups:
I am using 6.2.1 on cygwin / win XP
When plotting, using
   d.vect.chart fisk ctype=bar columns=F1992 size=10 scale=1.5
color=yellow
it looks fine, until I zoom or issue a d.redraw or a d.out.png.
but, if I add a max_ref:
   d.vect.chart fisk ctype=bar columns=F1992 size=20 max_ref=40 scale=10
color=yellow
it works fine all the time...
I can do some more investigation, but I do not have time at the moment.
Morten
-----Original Message-----
[mailto:grassuser-bounces@grass.itc.it] On Behalf Of Morten Sickel
Sent: Thursday, May 31, 2007 3:46 PM
To: grassuser@grass.itc.it
Subject: [GRASS-user] Error in d.vect.chart
Morten Sickel
grassuser mailing list
Hi Morten,
I added the max_ref flag, but have not experienced your problems. I am working
with the CVS version however. Can you post some of the particulars about the
data that you are plotting?
cheers,
dylan
color=yellow
color=yellow
Morten
Morten Sickel
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
