[GRASS-user] error message coming with r.colors
Dear list,
I try to adapt the color table of a raster file using an ascii file (> rules option) with the following statement:
r.colors map=b25_daymax0.l1_neu@PERMANENT color=rules 'rules=/sonne3/.../GIS/colorscript_farben_temp'
Hence the following message comes up:
"color", "rules", and "raster" options are mutually exclusive
Any ideas what this means? Please see also the attached colorscript.
Regards
Christian
_________________________________________________________________
Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy!
http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us
(attachments)
colorscript_farben_temp (123 Bytes)
What it says; you can't use both "color" and "rules". If you use
"color=rules", the rules are read from stdin (equivalent to -i). If
you use "rules=...", the rules are read from the specified file.
So, just omit the color=rules option, i.e.:
r.colors map=b25_daymax0.l1_neu@PERMANENT 'rules=/sonne3/.../GIS/colorscript_farben_temp'
2008/8/5 Glynn Clements <glynn@gclements.plus.com>:
hm, maybe quite confusing (at least for me). Can we change it in GRASS 7
color=rules
* rules not given or rules=-, read from stdin
* otherwise read from the file
and eliminate interactive mode
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
On Tue, 2008-08-05 at 21:30 +0200, Martin Landa wrote:
color=rules
Martin
I remember facing this error message some time ago which sounded very
logical. Since then I never force a "color" when I want to use "rules".
Maybe an additional reference in the manual wouldn't leave any space for
doubts.
2008/8/5 Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
doubts.
that 'color=rules rules=path_to_file' ends with the error is not so
much logical (in my eyes;-)
Martin
On Tue, 2008-08-05 at 22:47 +0200, Martin Landa wrote:
> doubts.
Martin
Martin,
you are (also) right. But in my case, I really never got tyrannised by
this module.
it seems to be a bug in r.colors, the attached patch quickly fix it.
It isn't a bug. color=rules was left as an "alias" for -i solely for
backwards compatibility.
Anyway r.colors needs some more cleaning. In GRASS7 I would suggest to
remove
-i Enter rules interactively
1) then if rules file is given read from the file
2) if not given (and color=rules) switch to the interactive mode
3) or completely remove interactive mode, print error about missing
rules file <- seems to be a better solution, to avoid any interactive
mode in GRASS7
If reading from stdin remains, it will be via -i, although I'm
inclined to simply remove the feature altogether (it doesn't work well
the GUI).
color=rules
The color=rules option will go. Note that the description of -i is
misleading; it reads rules from stdin, which can be redirected from a
file (you only get "interactive" behaviour if stdin is a tty).
Reading rules from stdin is a substantial deviation from normal
behaviour. If this feature remains (and I'm not sure that it should),
it should be a completely separate flag (i.e. -i), not just a
particular choice for the color= option.
Currently, there are four special cases for the color= option: random,
grey.eq, grey.log and rules. All other options just use the
corresponding rules file from $GISBASE/etc/colors.
The -g and -e switches make grey.log and grey.eq redundant, and -i
makes color=rules redundant, which leaves color=random as the only
special case (it cannot be implemented via a rules file, and only
works for integer maps). I'm considering making color=random a
separate flag.
By the way, something I don't understand (copy-paste from the manual):
The -e flag equalizes the original raster's color table. It can preclude
the need for grey.eq rule, when used as -e color=grey. Note however,
that this will not yield a color table identical to color=grey.eq,
because grey.eq scales the fraction by 256 to get a grey level, while -e
uses it to interpolate the original colour table.
> doubts.
Well, the error message seems clear enough:
The description of color=rules in the manpage is also quite clear:
       The rules color table type will cause r.colors to read color table
       specifications from standard input (stdin) and will build the color ta-
       ble accordingly.
However, it doesn't appear until around half-way through a fairly
large manpage.
For 6.3.1/6.4, it may be worth noting the mutual exclusion earlier on.
For 7.0, color=rules will disappear shortly.
It then goes on to say:
  If the original colour table is a 0-255 grey scale, -e is
  effectively scaling the fraction by 255. Different algorithms
  are used. -e is designed to work with any color table, both
  the floating point and the integer raster maps.
Essentially the only difference is in how a floating-point value
between 0 and 1 is converted to an integer between 0 and 255. In
practice, the difference will be invisible to the eye.
Here's a concrete example:
  $ r.colors elevation.dem -e color=grey
  Reading elevation.dem ...
  Color table for <elevation.dem> set to grey
  $ r.mapcalc 'tmp1 = r#elevation.dem'
  $ r.colors elevation.dem color=grey.eq
  Color table for <elevation.dem> set to grey.eq
  $ r.mapcalc 'tmp2 = r#elevation.dem'
  $ r.mapcalc 'diff = tmp1 - tmp2'
  $ r.stats -c diff
  -1 155417
  0 147001
  r.stats complete.
So, roughly half the cells are identical between the two, while half
differ by one intensity level.
I'm inclined to simply remove the feature altogether
(it doesn't work well the GUI).
I agree that -i is confusing from the auto-gen GUI.
Please keep the ability to pipe rules from stdin. I use it all the time,
both from the command line and within scripts when it is simple enough
that using a temp file would just be a waste.
e.g. the r.colors.stddev addons script.
I would be happy with removing color=rules and the -i flag *if* 'rules=-'
remained to tell it to expect data from stdin.
a particular choice for the color= option.
see also v.in.ascii, r.category, r.reclass, r.what, r.what.color, r.profile, ...
we should allow input from stdin for modules which it is useful, and we should do so in a standardized way across all modules. I am happy with the "rules=-" solution; I find adding flags for "expect from stdin" to be unneeded complication and highly confusing to new GUI users.
I wish to make the distinction between removing r.colors "interactive mode" and removing the ability to pipe from stdin rather than from a file.
I'm considering making color=random a separate flag.
example usage?
  "ERROR: colors= rules= and -random flag are mutually exclusive"
Hamish
Well; not just confusing. If you run a module from the GUI, and it
expects data from stdin, it's likely to wait forever for input which
will never come. The GUI should explicitly close stdin.
Note that r.colors doesn't currently understand "rules=-" (although
you can probably use e.g. rules=/dev/stdin).
I can see some advantage to using e.g. "rules=-", as it's easy for the
GUI to prevent this (just require that the answer to any old_file
option exists).
users.
Well, I've just started removing most of the explicitly interactive
stuff.
In the course of that, I've noticed at least one module (r.quant)
which only allows rules from stdin, not from a file. It wouldn't
surprise me if there are others.
We probably want a library function to fopen() an input file, which
returns stdin if "-" is given as the filename. There's still the issue
that any modules which need to seek will only work with a file, not a
pipe.
file.
example usage?
The flag would be equivalent to color=random, so it would exclude with
color= and anything which color= excludes.
OTOH, maybe it should be a separate module.
  $ r.stats -c diff
  -1 155417
  0 147001
  r.stats complete.
Thank you for your time and the concrete example. Nikos
