[GRASS-user] Error starting WinGrass 6.4.1 RC1
With the release of WinGrass 6.4.1 RC1 I decided to install. I've been
running WinGrass 6.4.0RC6-1 (March 2010) as it's been the only version
I can get to run on the PC. The PC is a relatively new (July 2010)
installation of WinXP + SP3 and to date, I have been unable to run any
newer versions of WinGrass (6.4.0, 6.4.0 SVN or 7.0 SVN).
I installed the new Grass 6.4.1 RC1. After starting the WinGRASS GUI
using the desktop shortcut, and selecting the demo data set (or any of
the existing data sets) the following error message is displayed...
Unable to get current geographic extent. Force quitting wxGUI. Please
run manually g.region to fix the problem.
Reason: No module named agw.customtreectrl
File "D:/GIS/GRASS-64/etc/wpython/wxgui.py", line 54, in <module>
  import wx.lib.agw.customtreectrl as CT
Import Error: No module named agw.customtreectrl
Any ideas on what the problem might be?
During the install process, there is a DOS command window opened to do
something - that window closes with a beep, so wonder if something
failed there?
Also, is there a log file created during the install process? or any
way of logging the install process?
Thanks in advance,
Sharon
2011/1/13 Sharon M <morrisxs09@gmail.com>:
try to run GRASS in the text mode and enter
g.region -p
what is the result?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Martin,
running g.region -p in WinGRASS 6.4.1RC1 text mode gets the error:
The ordinal 284 could not be found in the dynamic link library SSLEAY32.dll
Note: This is also the same error I get on startup for WinGRASS 7.0
Sharon
On Fri, Jan 14, 2011 at 6:39 AM, Martin Landa <landa.martin@gmail.com> wrote:
g.region -p
what is the result?
Martin
