[GRASS-user] Error when running SVN6.4.0.1 from 23/10
Hi there
I had in my OSGEO4W GRASSSVN6.4.0.1 from early September (after the release of 6.4.0) and it was running OK.I also was able to compile i.landsat.toar and .acca.
I decided to “upgrade” with SVN from 23/10 and I compiled it was all OK. I opened and I realized that the GUI was changed (I wasn’t expecting this)…But, ok… Irunned my scripts and I got an error while running i.landsat.acca saying that, to run it, I needed to recompile GRASS.
Than I decided to recompile acca I and I got this error:
ERROR: Incompatible library version for module. You need to rebuild GRASS
or untangle multiple installations.
WHat does this mean? What do I have to do?
This wasn’t nice but I just wnat to fix this
Thanks
~Franz
2010/11/1 Franz Schiller <franzschiller1975@gmail.com>:
I decided to "upgrade" with SVN from 23/10 and I compiled it was all OK. I opened and I realized that the GUI was changed (I wasn't expecting this)...But,
some development could be expected :wink:
http://grass.osgeo.org/wiki/Error_incompatible_library_version_for_module
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
You are absolutely right… but it was a massive implementation as far as I can see :slight_smile:
Uhm in my case I’m buidling it in OSGEO4W without using SVN (using weekly snapshots).
Do i just need to do?
make distclean and then run the mswindows.sh that is distributed (as usual)?
PS- About the r44109. Can I already download some files? (about the use of \ in file paths in Python-WinGRASS. Something that I really need
Thanks Franz
Martin
this)...But,
You are absolutely right.. but it was a massive implementation as far as I
wxGUI in GRASS 6.4 is almost one year old due to very long RC stage.
It decided to do this massive upgrade rather then to continue with
quite outdated version of wxGUI in GRASS 6.4.x.
> GRASS
Uhm in my case I'm buidling it in OSGEO4W without using SVN (using weekly
snapshots).
rm mswindows/osgeo4w/configure-stamp
./mswindows/osgeo4w/package.sh
Martin
Dear all
Is there a limit on the number of rasters for r.patch?
Sab
On Tue, Nov 2, 2010 at 2:03 PM, <razmjooeis@faunalia.co.uk> wrote:
Dear all
How funny, we had the same question at the same time... :slight_smile:
From GRASS 6.4+ there is no more limit despite the limit of open files per
process (which depends on the operating system; for Linux it is
usually 1024 files).
To increase that:
The limit of open files per process was reached (64bit Linux: 1024
files; ulimit -n)
To overcome this limit, the "nofile" parameter needs to be increased in the
/etc/security/limits.conf
file. Here an increase to 1500 files (use * instead of neteler to aply
it to all users):
#<domain> <type> <item> <value>
neteler hard nofile 1500
But myself, I got troubles when having registered the maps with r.external:
GRASS 6.4.1svn (patUTM32):~ > r.patch in=`g.mlist type=rast
pattern=dtm00* sep=comma mapset=dtm_1m_external` out=dtm_trentino_2m
ERROR 1: TIFFOpen:/geodata/base_cartography/pat_DTM_LIDAR_2007_UTM_WGS84/geotiffs/dtm000501.tif:
Too many open files
WARNING: Unable to open
       '/grassdata/patUTM32/dtm_1m_external/cell_misc/dtm000501/f_format'
WARNING: quantization file [dtm000501] in mapset [dtm_1m_external] missing
WARNING: Unable to open raster map <dtm000502@dtm_1m_external>
ERROR: One or more input raster maps not found
So far I could not find out the reason. Here I am using 500 files registered
with r.external.
Help welcome,
Hi Markus
Many thanks for your response. In the past versions, the patched raster
used to have an odd values.
I use Grass 6.4 from Ubuntu 10.10 64 bit repo.
Sab
Dear all
To increase that:
files; ulimit -n)
the
it to all users):
r.external:
ERROR 1:
Too many open files
registered
with r.external.
Help welcome,
On Tue, Nov 2, 2010 at 4:41 PM, <razmjooeis@faunalia.co.uk> wrote:
Hi Markus
No, this is rather impossible (perhaps you refer to the odd number of pixels
in a moving raster window).
Master question: how many files do you plan to patch?
Sab
Dear all
To increase that:
files; ulimit -n)
the
it to all users):
r.external:
ERROR 1:
Too many open files
registered
with r.external.
Help welcome,
it to all users):
Too many open files
This message matches strerror(EMFILE):
  #define EMFILE 24 /* Too many open files */
It's possible that some library (i.e. GDAL or TIFF) has its own limit,
and returns EMFILE if the limit is reached. But I'd start by assuming
that you're hitting an OS limit.
with r.external.
I assume that it's holding multiple open descriptors per map.
Note that 7.0 will typically have at least 2 open descriptors per map:
one for the raster data, the other for the null data. But not for
r.external "linked" files, which don't have a separate null file.
6.x doesn't keep the null file open, which reduces the number of open
descriptors at the expense of performance (open() can be fairly
expensive).
Run r.patch under gdb, set a breakpoint on G_fatal_error(). When the
breakpoint is hit, "ls -l /proc/<pid>/fd" (where <pid> is the PID of
the r.patch process) to see *which* files it has open. Or run r.patch
under strace, and manually examine the output to see which files are
open()ed and which are close()d.
I am having about 700 LiDAR tiles (~4 GB). Did it a couple of hours ago
and all worked well...the DTM looks as I expected!
The problem I had last year when I did it last, there were 1000+, values
for one tile were changed. Never investigated the problem. Simply
changed the region and things worked smoothly.
Many thanks
Sab
> Hi Markus
> Cheers
> Sab
>>> Dear all
>> To increase that:
>> files; ulimit -n)
>> the
>> it to all users):
>> r.external:
>> ERROR 1:
>> Too many open files
>> registered
>> with r.external.
>> Help welcome,
>> Markus
