Greetings
I have a Python script that is suppose to use g.mapset to change the current Mapset by running g.mapset but, everytime I run it I ge this error:
ERROR: Unable to read GIS_LOCK environment variable
Hi there
I have sent an email a couple of days ago reporting an error with g.mapset on Windows. Now I have also a problem with g.mapset on linux (a different one)
When I do:
g.mapset mapset=Regional
I get this in Output command window:
Erasing monitors…
PNG: GRASS_TRUECOLOR status: TRUE
PNG: collecting to file: map.png,
GRASS_WIDTH=768, GRASS_HEIGHT=501
ERROR: PNG: couldn’t open output file map.png
As anyone has any suggestion regarding this?
Thanks
Helena
one)
When I do:
Erasing monitors...
ERROR: PNG: couldn't open output file map.png
This suggests that you don't have write permission on the current
directory.
In 6.x, g.mapset restarts any active monitors, as any information
which they are storing will be invalid in the new mapset. By default,
the PNG driver sends its output to the file "map.png" in the current
directory; if you don't have write permission on the current
directory, you will get an error.
You can prevent this by specifying the PNG driver's output file using
an absolute path, e.g.:
export GRASS_PNGFILE=`pwd`/map.png
It worked
Thanks
Helena
On Thu, Sep 23, 2010 at 3:49 PM, Glynn Clements <glynn@gclements.plus.com> wrote:
one)
When I do:
Erasing monitors…
This suggests that you don’t have write permission on the current
directory.
the PNG driver sends its output to the file “map.png” in the current
directory; if you don’t have write permission on the current
You can prevent this by specifying the PNG driver’s output file using
export GRASS_PNGFILE=pwd
/map.png
