Hi All,
I am getting an error using i.colors.enhance on Windoes Grass 7.2.1 which crashes the session.
I get the following error in the command window.
Any advice would be greatly appreciated.
Andrew
((Sat Jul 15 14:25:12 2017)
i.colors.enhance red=s1_vv_10@PERMANENT green=s1_vh_10@PERMANENT blue=s1_10_diff@PERMANENT
Processing…
Process Process-3:
File “C:\Program Files (x86)\GRASS GIS
7.2.1\Python27\lib\multiprocessing\process.py”, line 258, in
_bootstrap
self.run()
7.2.1\Python27\lib\multiprocessing\process.py”, line 114, in
run
self._target(*self._args, **self._kwargs)
7.2.1\scripts[i.colors.enhance.py](http://i.colors.enhance.py)”, line 105, in
get_percentile_mp
result = get_percentile(map, percentiles)
7.2.1\scripts[i.colors.enhance.py](http://i.colors.enhance.py)”, line 89, in
get_percentile
percentiles=values, quiet=True)
7.2.1\etc\python\grass\script\core.py”, line 461, in
read_command
return handle_errors(returncode, stdout, args, kwargs)
7.2.1\etc\python\grass\script\core.py”, line 329, in
handle_errors
returncode=returncode)
CalledModuleError: Module run None [‘r.quantile’, ‘–q’,
‘input=s1_10_diff@PERMANENT’, ‘percentiles=2,98’] ended with
error
Process ended with non-zero return code 255. See errors in
the (error) output.
Process Process-1:
_bootstrap
self.run()
run
get_percentile_mp
get_percentile
read_command
handle_errors
‘input=s1_vv_10@PERMANENT’, ‘percentiles=2,98’] ended with
error
the (error) output.
Process Process-2:
_bootstrap
self.run()
run
get_percentile_mp
get_percentile
read_command
handle_errors
‘input=s1_vh_10@PERMANENT’, ‘percentiles=2,98’] ended with
error
the (error) output.
